Author Topic: SHAKER (4 barrel carb/air cleaner post/stud)?  (Read 3135 times)
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« on: April 18, 2013 - 03:32:07 AM »
Can anyone tell me were I can get a "correct" air cleaner stud/post for a 4 barrel SHAKER?  Not just a length of all-thread.  I had a correct length stud (with threads on each end), but the guy that rebuilt my engine 6 years ago never returned it, and he doesn't remember anything about it.  Thanks.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
Re: SHAKER (4 barrel carb/air cleaner post/stud)?
« Reply #1 on: April 22, 2013 - 01:52:58 PM »
Anybody??
Offline anlauto
« Last Edit: April 22, 2013 - 02:01:10 PM by anlauto »
Offline filmsurgeon
« Reply #3 on: April 22, 2013 - 07:08:45 PM »
What carburetor ? Here's Carter AVS http://www.ebay.com/itm/MOPAR-Carter-AVS-Air-Cleaner-Carb-Stud-Carburetor-4BBL-68-71-440-HP-69-70-Dodge-/230964706590?pt=Vintage_Car_Truck_Parts_Accessories&hash=item35c691bd1e&vxp=mtr#ht_1032wt_806
Thanks for the response.  Not quite sure it matters, but it's a Holley 4150.  The important thing is that the air-cleaner stud/post be long enough for use with a SHAKER.
Offline filmsurgeon
« Reply #4 on: April 25, 2013 - 01:44:53 AM »
 :popcorn:   :popcorn:   :popcorn:   :popcorn:   :popcorn:   :popcorn:
Offline tman
« Reply #5 on: April 25, 2013 - 02:33:28 AM »
Put your setup together and measure how long of a stud you need.  This place sells 3 different ones and you can contact them for the length, or maybe Mopar Dave at Roseville.
http://www.rocketresto.com/catalog/carburetor.html
Offline mopardave
  • Sponsor
    • rosevillemoparts
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline anlauto
« Reply #7 on: April 25, 2013 - 09:13:04 AM »
Shaker cars use the same carb studs as any other car.
Offline filmsurgeon
« Reply #8 on: April 25, 2013 - 01:22:07 PM »
I appreciate your feedback, but something tells me that's not necessarily true.  Why then was the stud that was returned to me by my engine guy too short?  Is there NO member on this forum that has an original SHAKER set-up (either assembled or unassembled) that can take a photo of their air cleaner stud (not some crappy "all-thread") against a tape measure, so I can see the proper lengths (total and threaded ends)?  Thanks.
Offline filmsurgeon
« Reply #9 on: April 29, 2013 - 04:48:33 AM »
 :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
Offline Jamiez
  • Retro
« Reply #10 on: April 29, 2013 - 06:26:22 AM »
Have you checked the MMC Detroit e body fastener guide?  I'm not sure carb studs are in it, but they are I'm sure it would list all the dimensions/finish/thread for the various options
Offline Jamiez
  • Retro
« Reply #11 on: April 29, 2013 - 06:19:08 PM »
Everything I see lists it by vendor and doesn't list any differences for a shaker.
a holley 4V would be 3.5" overall, .5 threaded on the carb side.  Thread on them is 1/4-20
Offline filmsurgeon
« Reply #12 on: May 03, 2013 - 01:39:18 PM »
Oh well  :dunno:  Since it appears that no one here has an original SHAKER set-up with an original air cleaner stud to measure and take a photo in order to help me out, I guess I'm gonna just have to wait until I get my carb back from being rebuilt so I can put my set-up together and take a measurement for the correct stud length.  Thanks to all who offered advice.
Offline anlauto
« Reply #13 on: May 03, 2013 - 03:34:00 PM »
 :iagree:  Not sure what source is telling you otherwise...
Offline filmsurgeon
« Reply #14 on: May 03, 2013 - 05:30:33 PM »
So, you're saying that ALL air-cleaner studs are the same length?
