Author Topic: Rear end placement?  (Read 667 times)
Offline CudamanTom
Rear end placement?
« on: April 18, 2013 - 11:41:47 AM »
Hello all,
Gotta a question.
Can a rear end on a 71 cuda be pulled back about an inch or two to accommodate a bit longer driveshaft or is that not an option?
I read somewhere about different lengths of driveshafts but didn't think R&R a 440 auto would make a difference.
I changed out a 440 auto with another and for some reason it doesn't seem the driveshaft (using the same one) will either slide into the tranny enough or the tranny is a little longer  :dunno:.
And just curious, how far in is the drive shaft supposed to slide into the tranny? Maybe that's what I need to look at first?  :clueless:
Thanks in advance.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Re: Rear end placement?
« Reply #1 on: April 18, 2013 - 11:48:39 AM »
if you relocate the rear diff it will look odd , I recall brad had a problem like this when he changed springs.
 the yolk should go all the way into the trans bascally right to where the yolk flares out fo rthe U joint , maybe there is a broken piece inside or the rear bushing is damaged
Offline CudamanTom
« Reply #2 on: April 18, 2013 - 12:21:27 PM »
Ah, you have a point on how it might look.
I will check for any obstruction on the inside.
Offline CudamanTom
« Reply #3 on: April 18, 2013 - 07:16:09 PM »
Well I must have had a bad day when trying to install the drive shaft a while back as it didn't want to go in all the way.
I tried it again today and it slipped right in.  :clueless: I feel like a dumb a$$. I mean good grief  :bricks1:
