Author Topic: exhaust kits  (Read 5150 times)
Offline CUDA8U
exhaust kits
« on: April 18, 2013 - 10:24:10 PM »
who makes the best aftermarket exhaust kit from x-pipe back to valance for an e-body ..3",currently have a summit racing x-pipe with headers
 :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada: :canada:
Offline blown motor
Re: exhaust kits
« Reply #1 on: April 18, 2013 - 10:39:00 PM »
I have Magnaflow
Re: exhaust kits
« Reply #2 on: April 19, 2013 - 02:51:49 AM »
TTI fit perfectly & will often have adapters to other makes of headers but you would probably have to replace the X pipe
Offline cudabob496
Re: exhaust kits
« Reply #3 on: April 19, 2013 - 04:42:33 AM »
TTI without a doubt
2011 Kawasaki Z1000
Re: exhaust kits
« Reply #4 on: April 19, 2013 - 09:15:53 AM »
I have Magnaflow
Same here, happy with it!
Offline high perf mopar
Re: exhaust kits
« Reply #5 on: April 19, 2013 - 08:55:21 PM »
TTI here,,bolts right in,best part is the stainless wide clamps that it came with,unlike the std u-bolts which crush the joints together," a U shape" u cannot remove them easily for servicing your car because of the indent, would buy again..  :2cents:
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline dougs bs23
Re: exhaust kits
« Reply #6 on: April 22, 2013 - 08:06:11 AM »
pypes performance exhaust,  less costly, stainless , fit well
Offline mojavered
  • Someday!
Re: exhaust kits
« Reply #7 on: April 22, 2013 - 08:53:26 PM »
A local muff shop with a mandrel bender...if you have one
Jason
Offline Mark8117
Re: exhaust kits
« Reply #8 on: May 07, 2013 - 01:16:49 PM »
TTI is the way to go, I just installed a full set on my 71 this past weekend.  :2thumbs: I had a Pypes set up on an A-body and we had to cut and weld a rear pipe to get it to line up right around the gas tank.
Offline 72challenged
Re: exhaust kits
« Reply #9 on: May 07, 2013 - 04:05:17 PM »
I wanted to use the TTI but was told (by them) that it would not work with factory rear swaybar, went with the Pypes system and had local installer tweak it!
72' Challenger Rallye, Lt Gunmetal Metallic, 360/4, 727, 8 3/4 sure grip, a/c ps pb, Bilsteins,  mini like wheels, BFG 245/60 15's
Thanks to R/T Spec., Year1, Jeg's, Napa Lyndon, Bohn services, Mopar Joe, Bell Motors, paint by Ray, Evans elect., MCB, Totally Stainless, Moparts, FBO, Mike the Car, Firm Feel, Unique Fab,
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
Re: exhaust kits
« Reply #10 on: May 08, 2013 - 01:06:13 PM »
I put a Magnaflow stainless system 2 1/2 on my 71 Cuda 340 (4-speed) last year.
Great initial deal as to price, looks / sounds great once on the car but lot's of modification to rear over axle pipes by professional intaller at The Mufflerman exhaust shop to get them to line up exactly with exhaust tip cutouts in rear valance!!
Offline anlauto
Re: exhaust kits
« Reply #11 on: May 08, 2013 - 02:03:08 PM »
Another vote for TTI :thumbsup: I've installed several of them
Offline all4rocks
Re: exhaust kits
« Reply #12 on: April 22, 2015 - 12:18:39 AM »
But what does the dyno max mufflers that come with the TTI sound like? I really like the sound of Magnaflows with an "H" pipe setup not the x pipe.
Offline tman
Re: exhaust kits
« Reply #13 on: April 22, 2015 - 12:33:04 AM »
TTi system comes with Dynomax SuperTurbos.  I like the sound.  Magnaflows are much louder.  You can check out a sound clip here.  Also, you can order a TTi system w/o mufflers so you can still add your Magnaflows.  Just go to the TTi website for info.
http://www.dynomax.com/sounds-of-dynomax/?muffler=super-turbo-muffler
http://www.ttiexhaust.com/Category-ClassicExhaust/HDRback.htm
Offline 1973JA5
Re: exhaust kits
« Reply #14 on: April 22, 2015 - 04:59:35 PM »
I've got Dynomax Super turbos,great sound without a headache!
