Author Topic: solid or not  (Read 2894 times)
Offline rattlesnake
  • Rattlesnake
solid or not
« on: April 21, 2013 - 01:04:12 PM »
ok, my 70 cuda has a mildly modified 440 hp. About 500 -600 horse I suspect. This is my second build for this engine. I am not sure if i want solid motor mounts or dampened. My goal is a fairly quiet comfortable car to drive 20 -30 times a summer. I am also realistic enough to know that I get a bit throttle happy occasionally and want to make sure the mounts hold up. What kind of vibration can i expect (is it teeth rattling)and what effect will it have on comfort. Are there other options?
keep honking I'm reloading
Offline high perf mopar
Re: solid or not
« Reply #1 on: April 21, 2013 - 03:35:03 PM »
this is what i have,,,its a combination of both..
http://www.engine-swaps.com/Pages/ProductsType/PolyLoc.html
B,C,E-Body Small Block & B/RB Poly-Locs
'66-72 B, 66-73 C, 70-74 E Small Block & B/RB Poly-Loc Set (All engines except S6 & Hemi)
BXEP* - $159 + $15 S&H
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline 72cudamaan
Re: solid or not
« Reply #2 on: April 21, 2013 - 05:01:09 PM »
Poly loc's are the way to go. Strength with a bit of cushion.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline cudabob496
Re: solid or not
« Reply #3 on: April 22, 2013 - 08:05:37 AM »
poly locks can fail.
use regular motor mounts, then use a Schumacher torque strap.
Thats been my setup for last 12 years, no problems. At least
580 ft-lbs torque, per the calculations anyway.
2011 Kawasaki Z1000
Offline 72cudamaan
Re: solid or not
« Reply #4 on: April 22, 2013 - 11:28:52 AM »
Personally, I've never seen a poly loc fail. And the OP wanted a quiet comfortable ride so why would he want to use a torque strap?
Offline mojavered
  • Someday!
Re: solid or not
« Reply #5 on: April 22, 2013 - 08:51:07 PM »
+1 for the poly locs
Jason
Re: solid or not
« Reply #6 on: April 22, 2013 - 09:26:10 PM »
torque strap with power steering can be a real problem,its in the way of everything,nothing will bolt right in..thats why i went poly-locs..
1971 barracuda
440-6 shaker
b-5 blue
Offline cudabob496
Re: solid or not
« Reply #7 on: April 23, 2013 - 06:19:30 AM »
We just had someone a few weeks ago report they had poly-locs fail on them.
If that happens, then a lot of damage could occur in your engine bay.
The torque strap from Schumacher is a long adjustable rod with large polymer bushings, which
don't affect ride quality. It only performs its function when you are at WOT, or close. Otherwise, you are just riding
on the stock motor mounts. It is a slick piece of engineering.
ya, i don't have power steering. Took it off to save about 60 pounds, and give me more
room around the headers.
http://www.engine-swaps.com/Pages/ProductsType/TorqueStraps.html
« Last Edit: April 23, 2013 - 07:04:56 AM by cudabob496 »
2011 Kawasaki Z1000
Re: solid or not
« Reply #8 on: April 23, 2013 - 08:13:03 AM »
I'm using both the poly locs and the shumacher torque strap. Works good for me. :2thumbs:
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
Re: solid or not
« Reply #9 on: April 23, 2013 - 01:59:58 PM »
ive seen one break and one melt my dads 440 challenger snapped it with ease after a year, the passenger side one on my challenger melted and plus with my big cam i got tired of feeling the engine rock through the frame. Plus if you ever look hard enough they change the drive line angle slightly since they raise the motor up a bit at least on my they did the motor sat  higher and messed up the tranny angle resortring in constant vibs i chased for a year pulled them out went to a sock set up  and installed a strap cars never ran better!
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline MTS-Challenger
  • Vanishing Point - "Catch Me If You Can"
Re: solid or not
« Reply #10 on: April 23, 2013 - 03:32:29 PM »
30 years ago I used a Moroso solid mount on the drivers side and stock rubber on the passenger and trans. Worked great in the day for a fair ride and held the BB motor down (stock ones would break on the first WOT from a stop), never had any issues. :2thumbs:
Now using MagMounts with a RB motor and no issues yet.  :)
http://chucker54.stores.yahoo.net/maheduenmo.html
 :2cents:
1970 Challenger R/T 440
Re: solid or not
« Reply #11 on: April 27, 2013 - 08:38:25 PM »
i think i will do the same next week with schmachers e-body new style hold down that clears all accs..
was going down the freeway today and under hard acc i started to feel a rumble for lack of a better word in the wheel that went away after pulling off the freeway,,WTF!..once back in the garage i noticed on the passenger side that the tie rod union was barely touching the passenger side header,,under hard acc the motor lifts up on the drivers side and rotates down on the passenger right into the headers/tie rod..
a little dimple with the ball peen hammer next week at that spot with the schmacher strap and should be good to go,,,
so much for thinking the poly-locs were an end all fix,,i would not have spent the xtra $$ for them if i would have known,,the schmacher strap would have been enough...so if anyone is thinking about them theres your answer,,,
1971 barracuda
440-6 shaker
b-5 blue
Offline BS CUDA
Re: solid or not
« Reply #12 on: April 27, 2013 - 08:48:36 PM »
 I have the poly locs (even pounded out a set last year) and the torque strap - still put a 1/16" spacer between the mount on passenger side to clear the passenger TTI header on the tie rod.   :dunno: :clueless: Always little obstacles when you wanna play hard / launch hard.
Re: solid or not
« Reply #13 on: April 27, 2013 - 08:59:00 PM »
thats interesting,,,i have TTI headers also,but now that its almost done,,for now,,thats not feasible,,the dimple i will have to put in that tube is very minor,,,and the torque strap should stop all contact..didn't notice it b-4 but with the new motor combo,,when i open up the 6-pak competition series mech outboards it snarls!!   :2thumbs:
1971 barracuda
440-6 shaker
b-5 blue
Re: solid or not
« Reply #14 on: April 27, 2013 - 09:02:31 PM »
I will probably fabricate a jumper strap from the engine block ear down the the cross bolt for the mount , completely hidden & unbreakable , I have done this on 2 cars & should have done mine also
