Author Topic: solid or not  (Read 2893 times)
Offline cudabob496
Re: solid or not
« Reply #15 on: April 27, 2013 - 09:15:36 PM »
Bummer is the Poly Locs were sold as the solution to needing a solid mount, but soft ride.
So looks like buyers were misled?
2011 Kawasaki Z1000
Offline high perf mopar
Re: solid or not
« Reply #16 on: April 27, 2013 - 09:25:26 PM »
I will probably fabricate a jumper strap from the engine block ear down the the cross bolt for the mount , completely hidden & unbreakable , I have done this on 2 cars & should have done mine also
i thought about getting creative but its all installed/driveable and need something that bolts right in...just bought the schmacher unit online to fix the problem,,,the clocks ticking on the up coming shows that i plan on attending,work keeps getting in the way,,,,
working for the man is WAY over rated,,but thats the world we live in,,,
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline Changin Gears
Re: solid or not
« Reply #17 on: April 27, 2013 - 09:43:48 PM »
I usually put the torque strap at the back of the engine, under the mater cylinder.
