yea not a fan of these carbs..but its on i will try to work with it for now..probaly a new carb in my future..lol..thx!
get a holley with 4 corner idle mix and you can also play with jets,floats,squirters,cams...............once you tune your holley they are awesome
i had a 600 eddy on my 440??? wen i got it,i bot a holley street hp 850(no horn),once i set the timing to 36 total i checked pump arm clearance at WOT,set floats to slow trickle,hook up vac guage and set 4 idle mix screws for best reading(in gear dist line plugged)
mine stumbled off the line so i upped the front squirter til it was gone(main jets 82 front 84 rear),next i jumped the rear squirter up 2 sizes,have someone follow you to see if there's a puff of smoke when you put er down on the highway,if there is drop a size
this thing is super responsive now although my pipes look a little black.It could be from cold
starts without a choke or puttin around town because it runs awesome......going to get it warmed up,change plugs and take it for a burn and look at plugs
