Author Topic: Squirter Survey  (Read 2697 times)
Offline cudabob496
Squirter Survey
« on: April 23, 2013 - 10:24:45 PM »
For you guys with an 850 Holley DP, what size squirters (accelerator pump nozzles) are you running on
the prim and sec side? Just wanna see what the ballpark is.  I've upped mine to 41, but my cams may need
changing as well.  When they were down around 31 to 35, I just didn't blast off the line like I wanted.
Thanks
« Last Edit: April 24, 2013 - 01:12:53 AM by cudabob496 »
2011 Kawasaki Z1000
Offline CUDA8U
Re: Squirter Survey
« Reply #1 on: April 24, 2013 - 12:22:08 AM »
changing as well.
82 front main
84 rear
34 front squirter
32 rear
4.5 power valve
what are details of your engine build and possible tuning probs are you having?
Offline cudabob496
Re: Squirter Survey
« Reply #2 on: April 24, 2013 - 01:14:55 AM »
82 front main
84 rear
34 front squirter
32 rear
4.5 power valve
496, 3500 stall, 3.91 rear, 254/258 at .050 .625 lift
Just seemed sluggish off the line
Going to 41s seemed to help.
thanks
2011 Kawasaki Z1000
Offline cudabob496
Re: Squirter Survey
« Reply #3 on: April 24, 2013 - 02:35:38 AM »
check out whats in my local paper
http://kpr.craigslist.org/cto/3761577379.html
2011 Kawasaki Z1000
Re: Squirter Survey
« Reply #4 on: April 24, 2013 - 07:43:06 AM »
41 is the upper range for me , rarely have I used squirters over 40
The Dart is wicked , I woul dhave to install buckets seats at least !!
Offline cudabob496
Re: Squirter Survey
« Reply #5 on: April 24, 2013 - 08:04:35 AM »
OK, once I get more aggressive cams in, I may try 35s!
2011 Kawasaki Z1000
Re: Squirter Survey
« Reply #6 on: April 24, 2013 - 06:50:44 PM »
On my Proform 850 DP, I have 78 primary jets, and 86 secondaries. This came like this, so by looking at my spark plugs, I saw no reason to tinker. It ran great until they started putting Ethanol in our gas.   :stomp:
I have since had to go to a .35 squirter back and front. I also had to change the front cam from pink to blue to get rid of my off idle stumble.
Re: Squirter Survey
« Reply #7 on: April 24, 2013 - 10:10:24 PM »
A bigger cam delivering more volume of fuel will not change a instant stumble , only the squirter will change that , a larger cam will deliver fuel longer
Offline cudabob496
Re: Squirter Survey
« Reply #8 on: April 24, 2013 - 10:35:52 PM »
Apparently Holley says to go to 50cc pumps, if your squirter is above 40.  Guess thats
because with more aggressive accel pump cams, you could run out of gas with a 30cc pump.
« Last Edit: April 25, 2013 - 06:34:35 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
Re: Squirter Survey
« Reply #9 on: April 24, 2013 - 10:37:42 PM »
Well what do you know! After changing jets every day for two weeks, since I got my AFR indicator, my 850 settled
on 78 primaries, and 86 secondaries. I shoulda just asked you!
2011 Kawasaki Z1000
Offline cudabob496
Re: Squirter Survey
« Reply #10 on: April 25, 2013 - 06:41:50 AM »
Is there any kinda rule or way to decide if the secondary cam should be more or less aggressive than
the primary cam.  For primary cam, coming off the line is a good way to gauge, but not sure how
to gauge what secondary cam is necessary?
2011 Kawasaki Z1000
Re: Squirter Survey
« Reply #11 on: April 25, 2013 - 01:46:10 PM »
less is often more as youalready have airflow start with the saem size front & rear , go smaller on the rear if there is no stuble keep going smaller
Offline cudabob496
Re: Squirter Survey
« Reply #12 on: April 29, 2013 - 08:40:03 PM »
wow, using blue cam, and 35 squirters, gave a smoother, stronger, and quicker acceleration!
2011 Kawasaki Z1000
Re: Squirter Survey
« Reply #13 on: April 29, 2013 - 09:13:03 PM »
 :2thumbs:
Offline cudabob496
Re: Squirter Survey
« Reply #14 on: April 30, 2013 - 06:29:26 AM »
is there supposed to be a small metal gasket above and below the squirter?
2011 Kawasaki Z1000
