Author Topic: Rallye Gauge Decals  (Read 1782 times)
Offline IroquoisPliskin
Rallye Gauge Decals
« on: April 26, 2013 - 08:33:34 AM »
Hello guys! Probably I will need to replace my speedometer face by a one with kph scale on it. I'm searching for a source for replacement. By now I found two suppliers:
1) Performance Car Graphics
http://www.performancecargraphics.com/Dash_Stuff/Gauge_Faces/E-body_Rallye.htm
2) Premium Dash Decals
http://www.premiumdashdecals.com/7074_ebody_rallye.htm
Does anyone have experience with those? Any recommendations?
Thanks!
(OO[ [ [ ] ] ]OO)
Offline blown motor
Re: Rallye Gauge Decals
« Reply #1 on: April 26, 2013 - 09:42:44 AM »
Why would you need to replace the speedo face with one that has klicks. I assume your from Canada buy your name but an old car is exempt as far as I know.
Offline anlauto
« Reply #2 on: April 26, 2013 - 10:22:01 AM »
I've tried the Premium Dash Decals before on a B Body with good results.....
Offline 70CUDA4SPEED
« Reply #3 on: April 26, 2013 - 11:50:25 AM »
I have this speedo, hes a friend of mine and restored my speedo, I will try to find a picture.
http://www.cuda-challenger.com/cc/index.php?topic=91494.0
« Reply #4 on: April 27, 2013 - 11:05:52 AM »
I'm trying to get the car on the road in Germany. The info from the technical surveillence agency around here says the speedo needs permanet marking in km/h. In that case I can better change the face decal on it.
I've seen the set recommended by 70CUDA4SPEED but its finish is glossy and I hope to be able to keep the original appearence.
Thanks for you input anyway.
(OO[ [ [ ] ] ]OO)
« Reply #5 on: April 27, 2013 - 01:51:25 PM »
Forget to say he has an improved version that is more identical to stock, I will take a picture of mine.
« Last Edit: April 27, 2013 - 02:04:40 PM by 70CUDA4SPEED »
« Reply #6 on: April 27, 2013 - 02:04:00 PM »
Here's a pic.
« Reply #7 on: April 28, 2013 - 01:11:23 PM »
Thanks for the picture! How doesnit look like in comparision to the original faces? I mean could you just replace the speedo face or did you have to replace all faces to make everything match? Are the faces some kind of sticker? Are they precut?
Thanks!
(OO[ [ [ ] ] ]OO)
« Reply #8 on: April 29, 2013 - 05:55:19 AM »
My dash is restored by just dashes so I will just replace the speedo, I will contact Tunis so he can jump in here with more info.
Offline HemiTunis
« Reply #9 on: April 29, 2013 - 06:54:25 AM »
Hi there,
I made the decals that 70CUDA4SPEED has on his speedo. I do not know how these compare to originals and even if they are 100 % correct, they will not look like a 40+ year old gauge face. I would recommend that you restore all of your gauges at once to get all the gauges the same.
If you need pictures of the decals/gauges let me know and I will take some pictures after work on a restored cluster I have and on the decals. I can only sell you all of the gauges or none at this time as I have a limited amount of decals printed.
They are precut on all but the oil, temp and fuel as I made an error on those. It is easy to lay out the decals on those gauges and cut out the hole perfectly from the back, that way it is also easier to line up the decals with the gauge face.
I hope this helps some.
Per
Edit: Forgot to say that I have both the glossy and a matte finish. The matte looks stock, the glossy gets a higher contrast as the whites shines more. Its your choice.
Thanks!
« Last Edit: April 29, 2013 - 02:38:52 PM by HemiTunis »
Per from Sweden
Vehicle fleet:
1971 472 Hemi 4-speed Cuda, under restoration
The one(s) that had to go to move forward in life:
1968 Dodge Charger R/T
1970 340 4-speed Cuda, matching numbers
« Reply #10 on: April 29, 2013 - 07:27:32 AM »
Found a pic before restoration.
« Reply #11 on: April 30, 2013 - 02:22:16 AM »
Thanks for the reply and the pics. It's helpful. I'll think about it.
(OO[ [ [ ] ] ]OO)
