Thanks gang! It's been loads of work on the hood because I accidentally used the wrong hardener in the black primer coat and ended up stripping back down to bare metal the next day..
So take note to always use a fresh hardener.. mine was old and didn't get hard. It was a disaster and I wanted to cry.
In all honesty however it was a blessing because after I got down to bare metal under the etch the media blaster did was a bit of rust, so I treated it and re etch primed the metal and primed and sanded it yesterday and also shot it yesterday.
My PPG guy said to do it all one day..
But I did and it looks okay after the first coat.
Concurrently working on the rear drivers side quarter panel where a patch was welded. I'm using fiberglass there and I really like the fiberglass better than run of the mill filler. It won't hold moisture either. It's more difficult to feather in but it is way more durable.
The front valence has shaped up nicely (broken bracket that was rewelded and a friend and I straghtened it)... Put it into build/sand primer tonight and hopefully will shoot it with color tomorrow.
Also started 400 sanding the car... I really wanna get it painted.
Been working like a dog, and taking 2.5 steps forward, and 2.1 steps back but hell at least it is moving forward. Instead of repairing the factory rear valence I've decided to order an AMD one that is EDP coated. It just isn't worth the effort to fix it. I think someone push the car with a hay fork and it is super rusty.
