Author Topic: Tire size for my Cuda  (Read 5344 times)
Offline pirate4x4
« on: April 30, 2013 - 05:13:38 AM »
I have ordered new rims for my 1971 Cuda...
Went for Cragar SS 610
Front 7x15  backspace 4 1/4
Rear 8x15   Backspace 4 1/2
The car  is stock hight, I was planning to go for 235/60 in front and 275/60 in the front, wil this work or is it to big??
Need to order tires today so please help me out!!
Offline moparman82
  • MOPAR or No car
  • Livin' the dream
Re: Tire size for my Cuda
« Reply #1 on: April 30, 2013 - 10:48:58 AM »
Should fit just fine, did a test for with same size/backspacing weld rodlites on mine with 235 in front and 255 in back, fronts fit great and there is lots of room in the back for more tire, I'll def be going 275 next time
Scott in Omaha
2015 crew cab Hemi ram SOLD
2019 Ram Laramie
2016 Tahoe LTZ SOLD
1976 Ramcharger 383 4spd SOLD
2016 Audi
24 mopars past and 2 present
Offline Bart
« Reply #2 on: April 30, 2013 - 03:43:23 PM »
P275 on the rear/235 both 60's
« Last Edit: May 02, 2013 - 06:47:26 PM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
Offline Racer57
« Reply #3 on: May 02, 2013 - 05:21:24 PM »
P275 on the rear
I recently bought this '70 BH with some "fixings", and I'm wanting to put the classic Cragar SS wheels on it. I was told that using a 15/7 with 4 1/4 backspace a 275/R60 on the rear would rub and to stick with a 255. Is there a reason you can use them and I can't or is the previous owner being overly cautious ? I'm also planning on a 15/6.5 and 235/R60 on the front, but would actually like to go a little narrower if practical.
Offline Bart
« Reply #4 on: May 02, 2013 - 06:18:47 PM »
Well I have a 15x8 on the rear and tried both 255 and 275, I would have to get air with the read to rub. We (Discount Tire and I) both pushed on the rear of the car and couldn't get the wheel well to hit the tire, the tire would rub if I go more than 1/2 down on the tire, don't plan on jumping the car.......don't know about a 275 on a7" rim.
Also have been driving the car and no rubbing hit a few driveways and no porblems....
« Last Edit: May 02, 2013 - 06:21:46 PM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: May 02, 2013 - 06:20:49 PM »
A 4.5" backspacing on the rear will allow you to run 275/60/15s or I'm in trouble!!!
 :droolingbounce:
Offline Racer57
« Reply #6 on: May 02, 2013 - 06:51:57 PM »
 :droolingbounce:
I was also told that 4.5 would cause issues with the suspension hitting. Is that with a 15/8  ?
NOW I'm really confused.  :eek7:
Offline Bart
« Reply #7 on: May 02, 2013 - 07:09:04 PM »
Yep 15x8 with 4.5bs
« Last Edit: May 02, 2013 - 07:21:42 PM by Bart »
1970 Cuda 383
2008 Titan
2010 G37s
2013 HD Roadking
« Reply #8 on: May 03, 2013 - 09:55:13 AM »
4.25 vs 4.5 is a very important quarter inch that can make a big difference in tire fit.
Also, keep in mind that if your quarter panels have been replaced, chances are the fender lip is now wider as well. Compared to the originals, reproduction quarters all have wider flanges in the wheel opening and very few body guys think to check this and trim them back to OEM spec.
Offline high perf mopar
« Reply #9 on: May 03, 2013 - 10:08:54 PM »
u should be fine with 275/60-15 in the rear ,thats what im running now,,295's were a little too close with stock spring perches..
a little tip,,i wanted my front tires to be a little taller and narrower than what a 235/60 could provide,anything 60 would be just as wide as the rear tire almost..,closer to the rears in height,,its all in the cross section,,,so,,after checking i bought 245/70's for the front...1/2" shorter than the rears but 2" narrower than the rears.i see alot of 70 series tires on the front of show cars because they look symetrical..looks even from the sides.but gives it that wide/narrow drag look from the front/back..    :2cents:
« Last Edit: May 03, 2013 - 10:11:00 PM by high perf mopar »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
