Author Topic: Front Suspension Assembly - New question  (Read 1380 times)
Offline CUDA JAS
  • vroooooom!
« on: May 03, 2013 - 08:18:57 AM »
I am finaly about to re assemble my front suspension (74 Cuda).
I got all my parts back from my painter and he painted all the holes in the upper and lower control arms (uper ball joint holes, bushing holes etc.)
I am assuming I should clean the paint out of these spots as much as possible before reassembly????
SO any other tips or trick on the reassembley.
I have a FSM.
I am using poly bushings and the moog offset uppers. On the LCA bushing, do I install these dry in to the LCA and lube the inside where the pin is inserted or do I lube both sides of the bushing?
Thansk for any help.
Jason
« Last Edit: May 06, 2013 - 10:32:18 PM by CUDA JAS »
74 'cuda 360/727
Just call me a gearhead!
Re: Front Suspension Assembly - Tips or tricks (and a question)
« Reply #1 on: May 03, 2013 - 10:04:06 PM »
Yes you want to remove the paint in the holes for bushings & ball joints , most bolot holes will be fine
 I lubed everything for the lower control arms pivot bushings . I also used Antisieze on every bolt & bolt hole  so upper control arm bolts cannot sieze inside the bushings , helps on any threads too .
 I started out setting the upper control arms with max caster adjustment so the front of the controlo arm is as far outward as possible & the rear inward . Make sure the lower control arms are dropped as far as possible before sliding in the T bars , I usually slide the bars in before connecting the lower ball joint to the spindle with the 2 large bolts .
Offline CUDA JAS
  • vroooooom!
Re: Front Suspension Assembly - New question!
« Reply #2 on: May 06, 2013 - 10:31:51 PM »
Thanks Neil.
Ok so I finaly got the pass side together.  Its not all torqued yet...but its together.
I put the T-bar in the LCA at full drop...I had to move the bar up a little bit to get the T-Bar in, as a result ther is a bit of a space between the T-bar adjuster and the adjuster arm.
I am running 1 inch Just susspension T-bars.
Is this OK?????
Here is a pic of the "free play" in the LCA.
74 'cuda 360/727
« Reply #3 on: May 06, 2013 - 11:11:29 PM »
Looks great to me!  :clapping:  Did you shot peen your spindles? They look nice! I assume you still have to install the LCA rubber bumpers?
« Last Edit: May 06, 2013 - 11:13:32 PM by brads70 »
« Reply #4 on: May 06, 2013 - 11:22:50 PM »
Looks right to me too , the LCA IS down & the lever is down as well , if you have extra space no problem .
Both the upper & lower control arm bumpers are off , coul dmake it tough to install uppers
« Last Edit: May 06, 2013 - 11:24:34 PM by Chryco Psycho »
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: May 07, 2013 - 08:32:26 AM »
Thanks guys.
Yep no bumpers yet...I figure the uppers will slip in once I have it at ride height.
Brad, the spindles are actually painted with Duplicolor Stainless steel paint.  I think the turned out preety good.  We will see how the stand up.
74 'cuda 360/727
Offline shoooter
« Reply #6 on: May 07, 2013 - 08:10:33 PM »
I have a FSM.
do you have a diagram of how everything goes together? I'm just about to put mine back in
Jason
