Author Topic: air cleaner size question  (Read 721 times)
Offline dutch
« on: May 03, 2013 - 01:03:09 PM »
I picked up this K&N filter element the other day. I got it at a great price so just couldn`t pass on it.  It  is an E- 1290.  11"x 2".   I read it is a replacement for 5.2 magnum and other not too big engines. Made me wonder how to determine if this, or any other filter element, has enough flow capacity for a 440?
If this one is not gonna work on my engine, what are my options for a small filter unit?  I like seeing some carb....
*** Bart ***
Offline cudabob496
Re: air cleaner size question
« Reply #1 on: May 03, 2013 - 06:05:10 PM »
see graph at bottom of page:
http://www.ramairbox.com/product.html
2011 Kawasaki Z1000
« Reply #2 on: May 03, 2013 - 09:41:45 PM »
i USE THE BIGGEST FILTER THAT WILL FIT  seems dumb to lose power over a small air filter , the filter top helps too
Offline cudabob496
« Reply #3 on: May 04, 2013 - 03:12:41 AM »
well, it has to look cool too!
but basically in an E body, you don't got a lot of room, without modifying stuff.
2011 Kawasaki Z1000
Offline dutch
« Reply #4 on: May 04, 2013 - 04:56:12 AM »
thanks.  That`s a cool link.  I s that the same set up you used?  Where does the passenger side tube pick up air?
I understand why bigger is better but looking at the factory dual snorkle filterbox with 2 small openings, an open 11x2 looks like serious improvement...?
What`s a good way to check max clearance under the hood? I was thinking maybe dots of clay on top of the filterbox then close the hood  :dunno:  any better ways?
*** Bart ***
Offline cudabob496
« Reply #5 on: May 04, 2013 - 05:27:40 PM »
playdough!! see link below:
http://www.cuda-challenger.com/cc/index.php?topic=90240.msg894376#msg894376
« Last Edit: May 04, 2013 - 05:45:22 PM by cudabob496 »
2011 Kawasaki Z1000
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: May 07, 2013 - 09:01:05 PM »
It's kinda funny when you see a big block engine with a little 6 inch diameter air filter.
Nice link, cudabob.  :thumbsup:
Offline cudabob496
« Reply #7 on: May 07, 2013 - 09:48:02 PM »
Ya, as many here know, an engine is like a giant air pump, and anywhere you restrict airflow, whether
air filter or exhaust, or in between, you limit power. Heads are one of the big culprits!
2011 Kawasaki Z1000
