Author Topic: Engine Turns over fine but won't start after storage??  (Read 5046 times)
Offline cudabob496
Re: Engine Turns over fine but won't start after storage??
« Reply #15 on: May 06, 2013 - 07:16:04 AM »
I got 2 ballast resistors in the glove box just in case, a replacement voltage regulator, and soon a spare ECU.
my engine use to quit, turned out the ecu was too close to the headers, and getting too hot. after it cooled down,
it would work again.
2011 Kawasaki Z1000
Offline 73EStroker
« Reply #16 on: May 06, 2013 - 05:08:25 PM »
You using Stabil in the gas tank. New modern gasolines are garbage for longer term storage. Try squirting some new gas down the chute but after what CP said to do.
Barry (Salmon Arm)
Offline jimynick
« Reply #17 on: May 06, 2013 - 09:36:07 PM »
One day I drove to the variety store in my 340 Dart, got out, made my purchase, came out and all she'd do was turn over. It was the GD ballast resistor and that's where my money is at here. good luck  :thumbsup:
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
« Reply #18 on: May 07, 2013 - 02:56:40 PM »
I'm going to try the new ballast resistor route first as pretty cheap to buy and if that doesn't work I will go on from there. Thanks for all the suggestions and hopefully will be back cruising in no time!!
Much Appreciated One and All.
"Tim"
Offline cudabob496
« Reply #19 on: May 07, 2013 - 09:52:12 PM »
"Tim"
Get'r runnin! There's Camaros to eat!!
2011 Kawasaki Z1000
Offline high perf mopar
« Reply #20 on: May 07, 2013 - 10:03:04 PM »
i know this does not apply to all original cars but, after seeing smoke coming from my original type installation""ballist resister" with a chrome box,,there supposed to do that at 1st,,yes they heat up to throttle current,,in went my MSD box..right where the windshield washer was supposed to go that i would never use,,,i dont even wash it with the garden hose,,,
the smoke coming from the fire wall upon start up was to say the least,,,alarming..... old school tech..
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline cudabob496
« Reply #21 on: May 08, 2013 - 04:32:30 AM »
Ya, I dumped the windshield washer motor, and the heater box.
2011 Kawasaki Z1000
Offline woody9512
« Reply #22 on: May 14, 2013 - 12:53:59 PM »
Car up and running now!! :cooldancing: :cooldancing:
Was the ballast resistor.........once off I saw the long shaft was actually broken inside it??
Thanks again for all the replies!!
"Tim"
« Reply #23 on: May 15, 2013 - 01:22:37 PM »
"Tim"
 :clapping:   go get another one for a spare in the glove box..... your going to need it! :2thumbs:
Offline cudabob496
« Reply #24 on: May 17, 2013 - 02:05:56 AM »
Dang, without going to an MSD system, you'd think we could come up with another mod
to eliminate the need for the ballast resistor, since it seems to be responsible for a lotta
Mopar folks being stranded on the side of the road! Come up with a good idea, and get rich!!
Or at least design a more durable/robust one!!! After all, we put a man on the moon in 1969!
Maybe put a bypass line around it, so you could flip a switch, and have current, as least to start you
and get you home, if the ballast resistor goes out!
« Last Edit: May 17, 2013 - 02:09:15 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
2011 Kawasaki Z1000
Offline CudamanTom
« Reply #26 on: May 17, 2013 - 08:11:04 AM »
found this:
http://www.moparmusclemagazine.com/techarticles/body/mopp_1110_ballast_resistor_guide_ballast_blast_off/
This article provides very good understanding of the ballast resistor and whether or not to use it. Thanks for sharing that Bob.  :2thumbs:
And it was simple enough for me to understand. And actually, this whole thread has been very helpful  :cheers:
I learn something new every day here at C-C.com  :woo:
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
