Author Topic: Remote ignition kill for security  (Read 3712 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: May 06, 2013 - 04:07:47 PM »
I was thinking yesterday about a way to make it harder for someone to take off with your ride. The thing in new vehicles is a push botton start that requires no key, just have to have the fob in your pocket the enable the car.
So has anyone seen something similar for a classic car?
I found this which is very close to what I am looking for  Car Defender
Only thing I don't like is that it requires you to hold the FOB at a certain place to allow you to start the car, then only gives you 5 sec to start it.
Also so this but it requires you to plug in a cap type deal to start the car.  Ravelco Anti Theft Device
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
  • I'm a llama!
Re: Remote ignition kill for security
« Reply #1 on: May 06, 2013 - 04:37:27 PM »
1971 Hemi Cuda
Offline RzeroB
  • In The Lou and looking for a new (old) ride
« Reply #2 on: May 06, 2013 - 05:56:22 PM »
One of those anti-theft systems may be some what effective, but older cars don't require multiple complex circuits to be energized in order to start and run. On a car like yours all someone needs is a jumper wire from the battery to the coil to energize the ignition, a screwdriver across the starter solenoid to jump the starter and varooom! the engine will come to life!
I have always liked a fuel cut-off valve. Someone might be able to hotwire your car, but they will only be able to get as far as the fuel in the carb float chambers will take them.
Cheers!
Tom
St Louis, MO
Former owner of 16 classic Mopars. "It is better to have owned (Mopars) and lost then to have never owned at all" (apologies to Alfred Lord Tennyson)
Offline RzeroB
« Reply #3 on: May 06, 2013 - 05:58:43 PM »
Then of course there is this option ...
Cheers!
Tom
St Louis, MO
« Reply #4 on: May 06, 2013 - 07:33:57 PM »
A friend had an immobilizer system in his Tahoe , it became problematic & would not let the car start , I pulled off the lower dash cover & reconnected the wires interupted & in well under 5 mins I had the system beat . My friend told his buddy who installed the system how fsat I beat it & he did not believe it .
Offline 73EStroker
« Reply #5 on: May 06, 2013 - 11:33:33 PM »
Just place a switch somewhere convenient like under dash or seat then split the wire to the coil (inside the taped loom and retape the two wires in) and run through the firewall under the carpet to where you like with a hidden toggle switch. Or you could do the same with the control wire to switch the starter. I just prefer that they never start the car at all. Thieves only have a few minutes to figure things out so this will help in most cases.
Barry (Salmon Arm)
« Reply #6 on: May 07, 2013 - 09:19:52 AM »
I have generally run a hidden ground off the tach feed wire , , you can hot wire the who;e system but it still will nto start unless you either find the ground switch or disconnect the tach wire from the coil
  • I'm a llama!
« Reply #7 on: May 07, 2013 - 12:08:52 PM »
I have thought of the switch deal. But then that is dependent on me activating it to work, I never forget anything. But I also hate the idea of an automatic system that is not reliable.
1971 Hemi Cuda
Offline high perf mopar
« Reply #8 on: May 07, 2013 - 08:48:17 PM »
my batterys in the trunk,,whenever i park it at the car shows or in the garage i have a battery disconnect switch on the negative post thats utilized...if they want it that bad where as they pry the trunk open,,,,i'll collect the classic car insurance i have on it   $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
  • I'm a llama!
« Reply #9 on: May 08, 2013 - 09:49:39 AM »
Does that still work with the factory tach?
What happens if they jump power to the coil? would have to think something is going to burn up with a dead short, wire, tach or something.
1971 Hemi Cuda
« Reply #10 on: May 09, 2013 - 04:37:59 PM »
Wow just typed out a long response & it vanished .
 Yes it will work with any tach  , you ground the tach feed wire from the coil not the power wire to the coil  , this way the ign will not generate a spark no matter what is hot wired & it will nto short .
Offline Fern
« Reply #11 on: May 09, 2013 - 06:28:20 PM »
I have been trying for some time to find a good cut off switch.
I would like to install a manual cut off switch tied to a vent pull, but cant find a cutoff with a top lever to attach the cable to. All manual cut off switches have a ball valve, and I would like to have one which I could use tied to a cable.
  • I'm a llama!
« Reply #12 on: May 10, 2013 - 09:28:10 AM »
Are you talking a battery disconnect? Somthing like this:
1971 Hemi Cuda
Offline Fern
« Reply #13 on: May 10, 2013 - 01:38:23 PM »
No, a solenoid type fuel cut off , only manually  operated by a cable.
  • I'm a llama!
« Reply #14 on: May 20, 2013 - 03:28:45 PM »
I was going to work on this but then got to thinking, scarry. I switch from the points to electronic ignion, so will it still work the same? Isn't the tach driven from the ECM now?
1971 Hemi Cuda
