Author Topic: main bearing clearances~are these ok?  (Read 761 times)
Offline bb71challenger
« on: May 06, 2013 - 10:35:52 PM »
I used some plastigauge on the mains today and got .003 on #1 and #5 and .0025 for #2, #3 and #4. When I got done and torqued everything down it spins nice and freely. I am just wondering what would cause those outside mains to be a different clearance.
*Brett*
Re: main bearing clearances~are these ok?
« Reply #1 on: May 06, 2013 - 11:17:34 PM »
I would shoot for .002 for a street engine , .003 is ok for higher rpm ,you may have trouble getting decent oil pressure with a std oil pump , was the block line bored ?
« Reply #2 on: May 07, 2013 - 01:38:30 AM »
The machinist said it was true as it came from the factory. Could it be the 440 source crank? I remember something about .003 being a good thing but maybe that was a drag engine. would a high volume or high pressure oil pump make things better? The guy actually told me that a standard oil pump would be fine especially since I was going to run a solid lift cam.
*Brett*
Offline 72cudamaan
« Reply #3 on: May 07, 2013 - 06:34:47 PM »
Could be the crank. Did the machinist measure it? Did he measure the main bores with ? without the bearings?
You may not have any issues with a .ooo5  variation. I like .0025 clearance myself. What kind of bearings are you using?
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #4 on: May 07, 2013 - 08:37:50 PM »
although the bolts were slightly wet they did not give like they should have and I did not wet them until I bolted the crank down. I think since I am barely into this I am going to pull it back down and make sure its all hunky dory. I am going to chase the threads to make sure they are clean and do it again. I think the bearings are Federal Mogul but I would have to look to make sure.
*Brett*
« Reply #5 on: May 07, 2013 - 08:39:06 PM »
main bearings are engine pro?
*Brett*
Offline high perf mopar
« Reply #6 on: May 07, 2013 - 08:42:10 PM »
nothing is precice across the journals unless its a nascar or nhra motor where thousands have been spent in machine shop hours to get it dead balls on..   2 1/2-3 thousands is acceptable for street/strip use,,my clearances r 3-3 1/2 mains and rods,,,did not want to grind the crank and take a chance on the outside crank grinder...oil pressure was 100+ with a high volume pump,,had to install a milodon adj oil pressure reg to turn it down,,using 20-50 oil...
i would call that racing clerance! u dont want a tight motor,,u should be fine.
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
« Reply #7 on: May 07, 2013 - 09:02:54 PM »
I generally use Michigan / Clevite 77 brgs . I would not use a high volume pump with a stock pan std volume with high pressure is fine
« Reply #8 on: May 07, 2013 - 09:11:51 PM »
The 440source crank requires radiused bearings if I remember right so that might explain the off brand bearings. I am going to check end play while I have it tightened down.
*Brett*
« Reply #9 on: May 07, 2013 - 09:41:13 PM »
this is why i let my machine shop determine what bearings i use per my requirements of clevit 77 full/3/4 grooved main bearings,witchever r ava for my app.mic them.fillet and non-fillet journals will require diff bearings,,and u dont have to try and use plastigauge to determine bearing clearnaces,,only use plastigauge if u have to...a couple xtra $$ at the shop to mic, but u will know exactly what u have..
when i got the motor back from the machine shop it was painting by the numbers,,bearing box 1 goes to journal number 1,,and so on..$$ well spent,,anybody can assembly an engine,,but we r NOT machineist's.....OH,,no dry threads!!!!use ARP lube on ARP bolts or,,oil on non ARP bolts..never dry!!!ANYWHERE!!!
« Last Edit: May 07, 2013 - 09:47:33 PM by high perf mopar »
1971 barracuda
440-6 shaker
b-5 blue
