Author Topic: Power Steering  (Read 994 times)
Offline BadJoey
Power Steering
« on: May 07, 2013 - 07:09:12 PM »
Wasn't sure where to ask this but I think this is close . If I accelerate real hard there is a racket under my hood . If I tighten the heck out of the power steering belt noise goes away but belt is toooo tight . It's not a squeeaing noise like a loose belt sounds like a rattle . Input shaft bearing feels tight by hand with belt off . The pump is old but hate to buy a new one just to test .Anyone ever come across anything like this before ? Thanks :clueless:
Offline 70383SE
Re: Power Steering
« Reply #1 on: May 09, 2013 - 11:52:45 PM »
Check to see if your fan is hitting the shroud on the rad. With the torque of the engine and the twisting motion, if there isn`t enough clearance around the shroud it makes a heck of a noise. Mine did, and had to put in more solid motor mounts and move the shroud and rad alittle.  :burnout:  :bigsmile:
Re: Power Steering
« Reply #2 on: May 10, 2013 - 12:07:35 AM »
Take the belt off and drive the car.  If the noise is still there, the pump is not your problem.  I agree with the above statement. A bad motor mount could be letting the fan hit the shroud.
Offline dutch
Re: Power Steering
« Reply #3 on: May 10, 2013 - 12:21:05 AM »
my belt is really close to the waterpump pulley... might be hitting on high rpm?
*** Bart ***
Offline BadJoey
Re: Power Steering
« Reply #4 on: May 10, 2013 - 11:17:52 PM »
Not the fan shroud . I'm wondering if it could be something inside the steering gear box . Its never been apart that I know of . Steering is loose but I've been blameing that on it being a old e body ?
Offline BIGSHCLUNK
Re: Power Steering
« Reply #5 on: May 11, 2013 - 10:04:57 AM »
I often get a squell from the belt. In my case this seems to be a "HEMI" thing because every one I look at has a rub mark on the fan pulley...  :dunno:  Something ?
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BadJoey
Re: Power Steering
« Reply #6 on: June 30, 2013 - 04:39:16 PM »
Changed the pump today $42.00 . Noise gone except at really high rpm's . I'm stumped . I wonder if my belt could be out of line . I got the motor in a box . To the eye it looks good . Going to wait and see for now . Could be my imagination but steering seems a lot tighter now ?
