Author Topic: Need Wix filter number  (Read 966 times)
Offline challenger_affair
« on: May 08, 2013 - 12:13:18 AM »
I have a 1970 383 challenger.  I've seen reference to both 51068 and 51515 Wix filters for these engines and I think the 51515 is longer.
Is there a reason to use one or the other?  Or any reason not to use one or the other?  Thanks!
1970 Challenger 383 RT Auto Plum Crazy
Offline cudabob496
Re: Need Wix filter number
« Reply #1 on: May 08, 2013 - 01:54:30 AM »
I would think the longer one has more filter material inside, so
it would last longer before clogging up.
I use K&Ns from Summit. They may have a higher burst strength.
K&Ns filter to 10 microns, I think. Not sure what the WIX filter to, but the
WIX have a good reputation for quality. K&Ns are supposed to have a
high tech synthetic filter material.
« Last Edit: May 10, 2013 - 01:43:14 AM by cudabob496 »
2011 Kawasaki Z1000
Offline Katfish
  • 70 Challenger
« Reply #2 on: May 08, 2013 - 05:55:08 AM »
Use the biggest filter you can fit.
Offline mrbill426
    • All Around Mopars
« Reply #3 on: May 08, 2013 - 09:51:09 AM »
FYI,
NAPA sells those same filters under #1068 and #1515; Wix filters with a NAPA label   :)
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline 72cudamaan
« Reply #4 on: May 08, 2013 - 06:32:56 PM »
Both filters are virtually identical. The 51515 is longer but the flow rate is the same, so use which ever
one fits best. And in Carquest the filter numbers are 85515 and 85068. Just FYI
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #5 on: May 08, 2013 - 10:35:59 PM »
Great info, thanks!   :thumbsup:
