Author Topic: Confused on carb sizes.... Thermoquad 750/800cfm vs Holley 650cfm  (Read 5334 times)
Offline Jamiez
  • Retro
Re: Confused on carb sizes.... Thermoquad 750/800cfm vs Holley 650cfm
« Reply #15 on: May 11, 2013 - 01:26:44 PM »
My Holley is a lot easier to adjust than the TQ.  For example you can set the float level on a holley without having to pull the carb apart.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #16 on: May 11, 2013 - 09:30:34 PM »
I would just grab the 650 Holley spread bore , tyr it , you will like it
Picked it up for $40.  Thanks!  :)  If anything I always have it as a spare, don't see them too often locally on craigslist.  A lot heavier than a Thermoquad!
« Reply #17 on: May 11, 2013 - 09:33:15 PM »
Uggh...of course this model doesn't have the external float adjustments.  Meant as a replacement for TQs qnd Quadrajets, not meant to be fiddled with I guess.  No secondary metering block.  Has a metering plate.
A web pic of the Holley 4165.
