Author Topic: That is it my car hates me  (Read 2855 times)
Offline 72cudamaan
Re: That is it my car hates me
« Reply #15 on: May 10, 2013 - 09:27:52 AM »
Sounds like the coolant isn't completely topped off so you might not see the flow. Most people don't
realize that a temp sender needs to be submerged in coolant to read properly. I.E a sender cant read air temp, so if
you're coolant is low you may be getting an inaccurate reading. Another good reason to try the thermometer in the rad. neck.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline 4 speed fish
« Reply #16 on: May 10, 2013 - 12:00:18 PM »
I would take the thermostat out.I would disconnect the radiator hoses from the radiator and run water from a garden hose thru the hose and see how the flow is coming out of the other hose.I would run the water in both directions.If there is good flow than it is probably the water pump.
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
« Reply #17 on: May 10, 2013 - 03:18:17 PM »
I see your point but this is a brand new pump and when I ran the car without the thermostat it moved water like a rapped. Everything is working and flowing until I put in a thermostat. I think 72Cudaman might be right. I do have a gap in the coolant and the top of the tank. I will put more in and fill the res. before testing. I think you may be on to something.
Offline 4Cruizn
  • HEMI FISH
« Reply #18 on: May 10, 2013 - 03:24:08 PM »
 :popcorn:
Offline Strawdawg
    • Vortex Buicks
« Reply #19 on: May 10, 2013 - 05:21:49 PM »
crank the car up and put your hand on the upper hose....if it gets hot, water is flowing thru it.   Or, take the thermostat out and put it in a pan of water and heat it up to see if it opens.  this should be a relatively simple procedure.
If there is not enuf water to cover the thermostat in the system, it will not open either.
Offline cudabob496
« Reply #20 on: May 10, 2013 - 06:23:42 PM »
My 72 service manual lists the following possible causes of overheating:
blocked radiator air passages
wrong timing
low engine oil
incorrect valve timing
inaccurate temp gauge/faulty temp sending unit
restricted overflow tube
faulty rad cap, fan drive unit, or vacuum bypass valve
2011 Kawasaki Z1000
« Reply #21 on: May 11, 2013 - 11:23:07 AM »
What make of thermostat are you using? I only use Stant , i have had numerous problems with Motorad & other off makes
Offline dutch
« Reply #22 on: May 11, 2013 - 01:33:25 PM »
I had a new motorad not open.   :2cents:
*** Bart ***
« Reply #23 on: May 12, 2013 - 11:59:39 PM »
Got the tools I need to check the temp Lazar / and / baking thermo. I will try to drive it again in the next day or so and let you know what happens.  :2thumbs:
Offline jimynick
« Reply #24 on: May 13, 2013 - 10:19:26 PM »
Not trying to be rude or a smarta$$, but is it possible you've got the 'stat in upside down? The pellet should be down in the block's water to open properly. Just my  :2cents:
Offline footin70rt
« Reply #25 on: May 14, 2013 - 12:24:34 AM »
This has some really good info here on the basics of cooling system operation.
http://www.stealth316.com/misc/grapeape-coolingsystems.pdf
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline Strawdawg
    • Vortex Buicks
« Reply #26 on: May 14, 2013 - 12:58:31 AM »
yes, that guy has some solid technical data
« Reply #27 on: May 14, 2013 - 05:42:56 PM »
 :working:
Time for the grand reveal. Today I drove the car about 30 minutes to the auto parts store to return some parts I was not using. It is about 95+ degree's here in Cali today so I though, hey this would be a great day to get stranded with an over heating challenger in a bad Long beach neighborhood.  :screwy:
So about half way to the auto parts store the temp kept climbing. I was about half gauge when I pulled over. I used my new lazer temp to search everything on the engine and radiator. Engine Block 178, radiator 159, lower hose 134, I jumped back in sure the gauge was to blame and drove the car on. The temp gauge started to drop but held a little less then half way. Ignoring it I finished my doings and came home. The temp held steady. I check everything. It was right where it should be. The temp sender was right at 180 where the thermostat should be. Long story short I should have listened to you all. It was only the gauge running a little high.
For those of you I should have listened to THANK YOU! You were right and I was jumping to conclusions.
For those of you that where wrong. THANK YOU! This site is wonderful because you get feedback and trouble shooting tips you never would have thought to check yourself.
THANK YOU ALL!
Offline Jamiez
  • Retro
« Reply #28 on: May 14, 2013 - 06:04:45 PM »
The reading of the gauge is a function of the sending unit...different units have different resistance...which makes the gauge read hit or low.  It's not really that precise of an instrument.
This thread talks about modifying the resistance to make the gauge read higher (most read low), but you could make a similar adjustment to make the gauge read lower.
http://www.cuda-challenger.com/cc/index.php?topic=77829.15
« Reply #29 on: May 14, 2013 - 07:34:03 PM »
thanks I totally see your point I will take a look.
