Cummins Diesel adapter kit for E-bodies ?
Author Topic: Cummins Diesel adapter kit for E-bodies ?  (Read 1291 times)
Offline Robb
« on: March 19, 2005 - 11:08:22 AM »
http://aey.is/kristjan/Notplayinggames.mpg
It was a slow loader this morning but worth the wait.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Killer_Mopar
Re: Cummins Diesel adapter kit for E-bodies ?
« Reply #1 on: March 19, 2005 - 11:57:08 AM »
I love seeing 2.5 tons of metal move that quick. That truck would be the ultimate sleeper, everyone would see the black smoke coming out the exhaust and think its a POS...I wanna see it break into the 10s. Would be quite funny seeings an e-body blowing out that much black smoke and only have 6 cylinders, the engine should fit......anyone up for a challenge?
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #2 on: March 19, 2005 - 05:22:47 PM »
That engine is way too tall to fit under and E-body hood.   Wayyy to heavy as well.
2013 Tige' RZR 343hp
Offline Robb
« Reply #3 on: March 19, 2005 - 10:35:30 PM »
« Reply #4 on: March 20, 2005 - 02:29:38 AM »
 I disagree , I measured it up & it would fit & is not significantly heavier than the 440 with A/C  , you would need a custom or dry sump pan
Offline JS27N0B
« Reply #5 on: March 20, 2005 - 09:17:11 PM »
C.P,
Have you seriously weighed these things? We have done a few short blocks on newer trucks and the engine is massive. Custom oilpan or not I wish you luck. The bare block sitting on the pan rail in the back of a truck bed is as high as the side of the truck box, add the head etc. I would think that this combo is probably about 8-12" higher from the pan rail up than a 440.
Offline 98hd
« Reply #6 on: March 20, 2005 - 09:41:31 PM »
After reading this topic I had to go measure........... from the bottom of the oil pan to the top of the valve cover on a B series cummins in an 03 dodge is 3ft!.
As far as weight I couldn't find a reliable number but they seem to be in the 1k range for a long block.
'72 barracuda....starting the restification!
« Reply #7 on: March 20, 2005 - 11:22:13 PM »
I did all the measurements once , about 3 months ago , I figured it can be done , variables include what trans to use , where the crank CL will be , with an auto matic it may sit 3" lower & the Charger budge hood was close to clearing , or a cowl hood can easily be used & the valve cover is the highest point , the turbo , exhaust  , Air cleaner are all remote , if it weighs 1000 lbs it is withing range , the biggest problem is strengthening the chassis enough to handle the torque & reinforcing the steering enough
 I have a spare Charger body & was already looking at it seriously but the usual lack of budget is killing me
Offline Ghost
  • I miss my Barracuda :(
« Reply #8 on: March 21, 2005 - 12:27:28 AM »
A new fund!  The CP Diesel Racer Fund!!! :laughing:
Offline Moparmatt
  • Mopar or No Car - Member Since 10/09/03
« Reply #9 on: March 21, 2005 - 03:35:45 PM »
Wcan fundraise at Carlisle...
Who was it that had the drawings a while back... post your ideas, Chryco, he can do some concept sketches, and then we can set up a fundraising campgain at Carlisle... make this car a reality for Carlisle 2006!
Or not, if you dont want to. :thumbs:
