Author Topic: how to tell if a motor is bored over?  (Read 1581 times)
Offline shoooter
« on: May 10, 2013 - 02:11:18 AM »
hey guys i have a 340 out of someone elses 71 cuda. I believe the motor is bored .60 over how can i tell? The heads are off the motor and there is a cracked piston. not sure if it is any good or not I will need to get it checked out. Now if it is already bored .60 over will it even still be good?
Offline cudabob496
Re: how to tell if a motor is bored over?
« Reply #1 on: May 10, 2013 - 07:14:56 AM »
gotta get a micrometer and measure.
normal bore 4.04 inches, so .060 inches over would be 4.1 inches
2011 Kawasaki Z1000
Offline 72cudamaan
« Reply #2 on: May 10, 2013 - 09:31:58 AM »
measure the bore with a bore gauge, or measure the piston skirt about 1 inch above the tail. If .060 over
and needs to be bored, it's useful life is pretty much over with. The cost of sleeving 8 cylinders gets pretty extreme.
I've done it for customers before but when you add 8 sleeves plus decking the block afterwards, most just buy another block.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Strawdawg
    • Vortex Buicks
« Reply #3 on: May 10, 2013 - 10:18:22 AM »
Look on the piston for a part number.
Offline Haddixj
« Reply #4 on: May 10, 2013 - 10:45:54 AM »
If you want a cheaper option use a set of cheap dial calipers from Harbor freight it measures to the thousandth. Also pistons usually will have the over bore on top of them like 30 or 60. What the Vin btw?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: May 10, 2013 - 12:06:45 PM »
Put on a karnac hat, stare at the 340 intently for 36 hours then open the envelope!!!
 :woohoo:
Offline shoooter
« Reply #6 on: May 10, 2013 - 12:44:31 PM »
motor 71 340 stamp number 1B378831. Also found trans OC141196.
Offline Haddixj
« Reply #7 on: May 10, 2013 - 01:02:26 PM »
 Swing and a miss for me. I will be on the lookout for 1b345796 340 block I have the matching 4spd trans
Offline shoooter
« Reply #8 on: May 10, 2013 - 02:31:02 PM »
Looks like its bored .60. Might be out of luck with this one
« Reply #9 on: May 11, 2013 - 11:19:23 AM »
not good , you may want to look at a 360 short block , lots around & cheap , could build a 408 stroker with a 360 block
