Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
pinion bearings
« previous
next »
Print
Pages: [
1
Author
Topic: pinion bearings (Read 611 times)
mopar jack
Full Member
pinion bearings
on:
May 11, 2013 - 10:29:55 AM »
I have a 742 case with 2.94 gears that I want to replace the bearings on. If I change the pinion bearings do I have to check or reset the pinion depth or can I reuse the spacers and install it?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: pinion bearings
Reply #1 on:
May 11, 2013 - 11:33:47 AM »
While the brgs "should" be exacttly the same they won't be , you need to recheck the depth unfortunatly
Logged
mopar jack
Full Member
Re: pinion bearings
Reply #2 on:
May 11, 2013 - 11:57:55 AM »
Thanks Chryco. I know how to set the carrier bearings for preload and backlash but I have never done the pinion before and I think you need a special arbour tool to set it. Maybe I'll send it to a shop and have it done.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: pinion bearings
Reply #3 on:
May 12, 2013 - 12:42:48 AM »
ypu can try it with the same shims & check the pattern on the gears , it may work out OK , if not have the pinion depth corrected
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
pinion bearings
