Sorry...not sure how else to describe it...LOL
Anyone have any tricks as far as how one could temporarily cap off the two rear brake lines while I have them disconnected to swap out the rear end housing and maybe convert drums to discs?
I have an adjustment valve inline for the rear but pretty sure it does not have a 100% "off" setting.
I will have the rear end apart for at least several days, my guess.....and if I run into trouble a week or two. I am trying to avoid having the system slowly bleed out those two rear lines and then having to bench bleed the MC, etc.
I had thought about maybe leaving the lines attached to the rear cylinder and just suspending the whole backing plate etc somehow, or maybe separating the cylinder form the plate and leaving that hooked up....
But wondering if maybe there is some sort of cap or fitting I can use that would be easier instead?
Ok, after you are done laughing at this newbie question, any feedback would be great! Thanks guys!
