Author Topic: Reversed Cables on Jump Start - No Ralley Gauges  (Read 1281 times)
Offline 70redchallenger
  • Newbie
« on: May 13, 2013 - 06:10:29 PM »
Rough day.  Body shop drained battery on my 70 Dodge Challenger and proceeded to apply booster cables to start.  Problem is they installed the cables in reverse order.  Obvious problem was the blown fusible link.  Replaced the fusible link and vehicle now runs.  The fuel gauge, oil pressure gauge and temperature gauge are not working.  I am not sure where to start.  Any suggestions out there?  I have reviewed a few other posts but sense my problem today is a bit different than anything else out there already answered and I am reluctant to start tearing things apart if there is a simple solution.  Thanks for any responses.
Michael D.
Bismarck, ND
70 Dodge Challenger
383 Automatic
Offline JayBee
Re: Reversed Cables on Jump Start - No Ralley Gauges
« Reply #1 on: May 13, 2013 - 07:15:34 PM »
Odds are the 5 volt limiter on the back of the gauges is fried. It converts the car's 12v to 5v for those 3 gauges. It's the only thing that is common to all 3.
http://www.ebay.com/itm/Solid-State-Mopar-Limiter-IVR3-bolt-on-Challenger-Cuda-B-body-Rallye-/380599172049?pt=Vintage_Car_Truck_Parts_Accessories&hash=item589d7a7bd1&vxp=mtr#ht_354wt_679
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline 72cudamaan
« Reply #2 on: May 13, 2013 - 09:07:11 PM »
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #3 on: May 13, 2013 - 09:13:49 PM »
Bummer!  I expect the diode in your alternator got fried as well.
The Brewmaster
Offline moparelwood
« Reply #4 on: May 14, 2013 - 12:22:14 AM »
 :iagree:  Check out this link for some very good info on the voltage regulator
http://www.allpar.com/history/mopar/electrical2.html
Good luck
« Reply #5 on: May 14, 2013 - 08:48:34 AM »
I agree, probably regulator, but reversing the polarity on a bimetal strip shouldn't be a big deal, at least I wouldn't have thought it would be a big deal. Evidence suggests otherwise though.. unless of course it was replaced with an electronic one already.
  • Newbie
« Reply #6 on: May 14, 2013 - 09:33:45 AM »
Great suggestions.  Seems like the way to go is replace the limiter on the back side of the gauges.  Thanks for the suggestions and pointers to ebay.  Will be back in a few days with the results.
Mike D.
« Reply #7 on: May 15, 2013 - 01:58:07 AM »
I would be thinking about moving the whole car out of their shop , not too bright !!
