Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
clutch fork and z bar set up
« previous
next »
Print
Pages: [
1
Author
Topic: clutch fork and z bar set up (Read 931 times)
raj
Jr. Member
on:
May 13, 2013 - 09:17:00 PM »
I need some help with my 4 speed set up. I have a 73 340 4 speed car I put a 440 in it back in the 80s ran a 4 speed for a couple of years then changed up to an automatic. I have put the car back on the road with the 440 and a four speed. Here is the problem. my clutch fork sits low in the bell housing about a 1/2 " off the housing, about 2 1/2" above. I cannot get the proper pedal play and my clutch is at the floor. I purchase a new big block fork and adjusting rod as well. I am presuming that I may have to replace the Z bar as well. Can anyone give me some Ideas or solutions. Also would like to purchase a new big block rad if you have some suggestions. Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: clutch fork and z bar set up
Reply #1 on:
May 14, 2013 - 06:29:34 PM »
I would contact Brewers for info & parts
Logged
Changin Gears
Sr. Member
Reply #2 on:
May 15, 2013 - 12:12:13 PM »
Sounds to me like you have the wrong clutch fork pivot. That's what dictates what angle the fork exits the bellhousing.
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #3 on:
May 15, 2013 - 12:25:39 PM »
Is the Z Bar level in the car ?
Logged
raj
Jr. Member
Reply #4 on:
May 16, 2013 - 03:50:02 PM »
Thanks for the replies.The Z bar is level and square. The pivot makes sense That could also cause my inability to get the proper adjustment off the floor. Any Idea where I could find some info on the pivot. Thanks
Logged
KillerBee
Jr. Member
Reply #5 on:
May 21, 2013 - 08:49:38 AM »
Brewers sells the pivots.
http://www.brewersperformance.com/products.asp?cat=103
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
