Author Topic: Couple 727 questions  (Read 545 times)
Offline 72challenged
« on: May 16, 2013 - 05:43:11 PM »
if my 727 trans is slightly over full 1/4 inch on dipstick, will it push fluid out?
my tach "seemed" to be reading higher RPMs than should have @ hwy cruising speeds, now that I have adjusted the downshift cable, the RPMs seem correct but now I am having the 1st problem with oil leaking?
1-2 upshift @ normal driving speeds is good but now 2-3 shift is slightly delayed  & firmer (also after cable adjustment)
tia, eh
« Last Edit: May 16, 2013 - 10:08:27 PM by 72challenged »
72' Challenger Rallye, Lt Gunmetal Metallic, 360/4, 727, 8 3/4 sure grip, a/c ps pb, Bilsteins,  mini like wheels, BFG 245/60 15's
Thanks to R/T Spec., Year1, Jeg's, Napa Lyndon, Bohn services, Mopar Joe, Bell Motors, paint by Ray, Evans elect., MCB, Totally Stainless, Moparts, FBO, Mike the Car, Firm Feel, Unique Fab,
Re: Couple 727 questions
« Reply #1 on: May 16, 2013 - 09:02:59 PM »
The downshift cable will adjust shift RPM so that is normal
Where is the leak , it should not leak 1/4" over full but you can crack a cooler line & bleed some fluid back out .
