Author Topic: heater box removal AC car  (Read 1315 times)
Offline shoooter
« on: May 17, 2013 - 12:47:19 AM »
Whats the easiest way to remove the heater box on a AC car? I did i search and came up with this. I believe it was for a 70 cuda:
"If its an A/C box the box itself has threaded studs that poke through the firewall that attach with nuts on the engine compartment side of firewall.  There are 3 nuts around the blower motor then 3 or 4 more nuts kinda evenly spaced across the firewall from the blower motor area over towards the drivers side of the firewall.  Then there is a hanger support bracket on the dash frame that connects to the front of the box behind the glove box insert.  I just went through replacing a heater core in an A/C box on my 70 Cuda and it also took me a bit to figure out how it mounted. "
 I have my dash frame out of the car right now and cant seem to get access to the inside of the box? suggestions? thanks :cheers:
Offline 4Cruizn
  • HEMI FISH
Re: heater box removal AC car
« Reply #1 on: May 17, 2013 - 09:40:42 AM »
Did you undo the 3 nuts that hold the heater box in that are located on the firewall?
Offline shoooter
« Reply #2 on: May 17, 2013 - 11:15:24 PM »
Yup got the nuts off the firewall side. Would the ac lines be holding it in? Or do I need to pull something off the front
Offline dutch
« Reply #3 on: May 18, 2013 - 06:53:24 AM »
maybe the fresh air intake seal on top is a bit sticky?  or the foam seals around the ac lines?  If you only need acces to the inside ,I think you can take off the front half of the box. It`s held together by metal clips.
If the ac lines are still connected, you cant get the box out.
*** Bart ***
Offline anlauto
« Reply #4 on: May 18, 2013 - 07:44:52 AM »
If you want to remove the whole "heater box" you're going to have to undo all the A/C and heater connections inside the engine compartment as well.
Offline shoooter
« Reply #5 on: May 19, 2013 - 12:39:38 PM »
What's the best way to get the connections off? Do they need to be cut ?
Offline anlauto
« Reply #6 on: May 19, 2013 - 01:52:51 PM »
The two A/C line have threaded connectors...the two heater hoses are just hoses/clamps.
Offline shoooter
« Reply #7 on: May 19, 2013 - 06:58:50 PM »
 :feedback: thanks for the help. Got it out
Offline elmoska
« Reply #8 on: September 23, 2013 - 07:16:13 PM »
I removed my heater box and now i want to replace my heater core,where do you guys buy yours, because i bought mine at napa's and its far from the original for 100$
1974 challenger on its way..
Offline ToxicWolf
« Reply #9 on: September 27, 2013 - 09:23:48 PM »
Check this:
http://www.cuda-challenger.com/cc/index.php?topic=95163.0
