Author Topic: Flow numbers for different size paper carb air filters  (Read 499 times)
Offline cudabob496
« on: May 17, 2013 - 07:35:02 AM »
I'm using the 14" X 4" @110 for my 850 Holley.
http://www.ramairbox.com/flowtest.html
Also, check out cool 16 inch filter at bottom of page. They adapt a 14 inch lid to
a 16 inch filter:
http://www.ramairbox.com/filter.html
« Last Edit: May 17, 2013 - 07:43:33 AM by cudabob496 »
2011 Kawasaki Z1000
Offline HP_Cuda
  • Mopar or No Car!
Re: Flow numbers for different size paper carb air filters
« Reply #1 on: May 17, 2013 - 03:46:57 PM »
You know what would be cool is to take folks dyno numbers here and compare what kind of element setup they used to achieve their numbers.
Offline cudabob496
« Reply #2 on: May 18, 2013 - 07:36:01 PM »
Ya, most likely the largest and least restrictive air filter would make the most power. Though there are
air filter housings that have a curved base and top to redirect air flow better to the carb (make
it more laminar). Ramairbox has some.
2011 Kawasaki Z1000
