Author Topic: Driveshaft Question  (Read 756 times)
Offline roy282
Driveshaft Question
« on: May 17, 2013 - 03:51:29 PM »
I have a Factory 383 big block drive shaft with automatic trans for a 1970 E Body barracuda and my QUESTION IS
I did a four speed conversion and I will be buying a Dana60  from DR. Diff and I want to know will the factory driveshaft need to be shorted ?
If so what would be the length?
Thanks Rob
« Last Edit: May 17, 2013 - 03:58:14 PM by roy282 »
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline Katfish
  • 70 Challenger
Re: Driveshaft Question
« Reply #1 on: May 17, 2013 - 04:00:30 PM »
Dana takes a 1" shorter driveshaft from the factory.
I'd try it before cutting or getting another.
I went ahead and bought a 1" shorter DS when I put in my Dana, looking back on it, I'm pretty sure the original DS would have worked fine.  :2cents:
http://board.moparts.org/ubbthreads/upload2/4563759-PartNoDriveshafts.pdf
« Reply #2 on: May 17, 2013 - 10:12:04 PM »
This assuming you did have an 8 3/4 diff before  :misbehaving:
Offline roy282
« Reply #3 on: May 18, 2013 - 01:10:58 AM »
Yes 8 3/4 before.
Offline roy282
« Reply #4 on: May 19, 2013 - 08:41:16 AM »
Thanks for your reply's so what you are saying is that it should be one inch shorter?
My drive shaft is bent so I was going to have one made but do you think I should what till I put everything back on the car and then measure it?  OR is it safe to say it's one inch shorter??
That's with a 383 and 4spd and dana60 from DR Diff in a 70 barracuda gran coupe.
Thanks Rob
« Reply #5 on: May 19, 2013 - 12:08:55 PM »
Personally I would wait , try the bent shaft you have & go from there
Offline roy282
« Reply #6 on: May 22, 2013 - 04:38:26 PM »
Thanks I think I'll just wait.
Thanks Rob
