Author Topic: 17 Inch Wide Rims ???  (Read 1827 times)
Offline Aus_Cuda
« on: May 18, 2013 - 04:13:23 AM »
I'm trying to find someone that makes a Nascar style steel wheel in a decent width.
The widest I can find is 17x9 but I want 17x11 or at least 17x10. They needs to be able to be ordered custom for the correct offset.
Has anyone come across anything ????
Re: 17 Inch Wide Rims ???
« Reply #1 on: May 18, 2013 - 07:23:48 PM »
No problem with a 2 or 3 piece alum wheel but in steel I have not seen anything wider than 10"
Offline RCCDrew
« Reply #2 on: May 18, 2013 - 10:52:59 PM »
Stockton wheel? Maybe Bart wheels.
Offline RCCDrew
« Reply #3 on: May 18, 2013 - 10:54:49 PM »
Some places can cut and weld 2 rims together.
« Reply #4 on: May 20, 2013 - 09:17:37 AM »
So you want a 17x17 steel wheel?
I've never seen such a thing and the weight on them is going to be just like their size: enormous. This is going to be a specialized, custom build.
Even in 15" diameters, I don't think I've ever seen a 17" width. It just an oddball size. I have seen 15x12, even 15x14, but never a 17".
In Nascer styles, 15" diameters are the norm as that is what the sanctioning body rules require. The only time I've seen a 17" diameter nascar style wheel was on the Ray Evernham '64 Plymouth build, and those were one off custom units that retained the Nascar spec 9.5" width.
Offline drewcrane
« Reply #5 on: May 20, 2013 - 11:32:35 AM »
What kind of tire would fit?
Offline Aus_Cuda
« Reply #6 on: May 21, 2013 - 04:51:22 AM »
No not 17 inch wide !!!!!!
17 diameter with 9" wide front  & 11" wide rears
« Reply #7 on: May 23, 2013 - 03:23:53 PM »
Try these guys, they offer 17x11 shells and D window centers. They can even weld them all up for you. They say $180 per wheel and I'd guess they are going to weigh in around 50-60# each. These are designed as a non bead lock rim for use on off road vehicles, so durability is more important than weight.
http://www.mrt-wheels.com/catpages/wheel%20parts.html
