I check the bell housing and that looks fine. I would think if that was misaligned, you would have other problems too. I removed and reinstalled the rods, but I moved them down to the second hole near the lever installing nut. This would give the rods more travel. I have driven the Cuda two times of about 10 miles each and it does not jump out of gear. I will have to do some more road tests to make sure. Thanks for the help and I will keep you posted.
