Except any oil will get saturated with fuel if the cylinders are getting washed down. That's still not good.
Totally agree, not good. Just saying a light weight synthetic oil will re-coat the cylinder walls
quicker.
Not sure I can see how pumping a Holley 5 times is gonna wash all the oil off
all the cylinder walls on startup, but not an expert in this area.
Nother good reason to use Engine Restore. Fills in scratches on cylinder walls in older engines,
restores cylinder pressure, and reduces oil consumption. I use it on all my oil changes, as engine is 12 years old now. Its
also beneficial as I used the thinner piston rings, which are prone to more oil consumption (but allow you to make more power,
due to less friction between rings and cylinder walls).
