I was under the car going through the front brakes(drums).
I felt a little free play when I grabbed the drum and rotated it back and forth moving the steering parts.
I discovered the idler arm was moving up and down.
I know the original ones are rebuildable but I bought a brand new Moog off E-bay for $32.
I'll keep the original with all the other original parts I took off the car.
I need to get the car up on the lift anyway and install a fuel return line as I had it out the other day in humid high 80 degree weather and noticed a hint of vapor lock.
Should be an easy swap up on the lift.
Thanks.
