Author Topic: Smoking??????  (Read 3450 times)
Offline Dusty1
  • Revived
Smoking??????
« on: May 20, 2013 - 11:57:30 PM »
Brake-in doesn't seem to be taking. About 100 miles on the 340 and lots of run time getting ignition all adjusted, and it seems to be smoking worse now than when I first started it. It still has the cam brake in oil in it and I keep getting told to put miles on it, but it doesn't seem to be getting any better. Leaves a bad cloud especially on decelleration. Could the rings still not be seated? Thanks
Garys 1972 BS
Re: Smoking??????
« Reply #1 on: May 21, 2013 - 01:40:30 AM »
What rings were used , I had Chrome moly in one engine , the engine was still picking up more power with 6 k miles on it , no chance any of the rings were broken on installation ? or installed upside down ?
Offline cudabob496
Re: Smoking??????
« Reply #2 on: May 21, 2013 - 06:06:46 AM »
had similar symptoms once. Valve guides!
Or, intake not sealed well against heads, and oil is being drawn into
heads past intake gasket.
2011 Kawasaki Z1000
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Smoking??????
« Reply #3 on: May 21, 2013 - 10:02:15 AM »
If you let it run and then let it sit for like 10-15 minutes and then restart do you see smoke come out on start up?  If so, it may be like cudabob said, valve guide seals.
When else does it smoke besides on decel?  :clueless:
Re: Smoking??????
« Reply #4 on: May 21, 2013 - 12:16:52 PM »
With the throttle closed youhave very high vacuum on the intake side so it definatly could be intake gasket too or intake guides
Offline HP_Cuda
  • Mopar or No Car!
Re: Smoking??????
« Reply #5 on: May 21, 2013 - 01:30:15 PM »
Is the cloud a white dissapating one or one that hangs around awhile?
My guess is the rings haven't seated yet and you are seeing oil burn.
Re: Smoking??????
« Reply #6 on: May 21, 2013 - 07:39:00 PM »
Cool!  So that's the science behind it!  Thanks!  :thumbsup:
Re: Smoking??????
« Reply #7 on: May 21, 2013 - 09:18:12 PM »
Yup , the engine is turning fast / above idle speed , the throttle is closed there is no air getting in , the vacuum could exceed 20" easily
Offline cudabob496
Re: Smoking??????
« Reply #8 on: May 21, 2013 - 10:08:59 PM »
if heads or intake have had any machining, then that can set you up for leakage past the intake gasket.
I had to use two intake gaskets per side to seal things properly.
2011 Kawasaki Z1000
Offline KingCuda440
Smoking??????
« Reply #9 on: May 21, 2013 - 11:36:31 PM »
I had a small block smoke like that after I changed an intake. It turned out there was a hole in the exhaust crossover and it was sucking oil. I would also check valve stem seals and valve guides.
Another thing to consider would be to run a compression test.  One last thing, when you say break in oil I'm assuming it's conventional oil as synthetic would cause the rings not to seat properly.
Offline Dusty1
  • Revived
Re: Smoking??????
« Reply #10 on: May 22, 2013 - 11:24:38 PM »
Seal power rings, the heads are shaved and it does have conventional oil in it with cam breakin additive. Motor built by a good performance engine shop(anything can go wrong). Very little smoke when started up or on reving. When driving I can see that its leaving a slight smoke trail, I get out of the gas for a red light and on initial acceleration heavy smoke rolls up behind me, like it loaded up during decelleration. No blow by at the valve cover filler hole and no unusual oil in the pcv hose.
« Last Edit: May 22, 2013 - 11:27:51 PM by Dusty1 »
Garys 1972 BS
Offline cudabob496
Re: Smoking??????
« Reply #11 on: May 22, 2013 - 11:35:49 PM »
Constant smoke down the road is usually rings.  Smoke during acceleration off the line is usually valve guides.
2011 Kawasaki Z1000
Offline Dusty1
  • Revived
Re: Smoking??????
« Reply #12 on: May 22, 2013 - 11:39:10 PM »
Maybe its just not seated yet(I hope). Engine builder said drive it?
Garys 1972 BS
Re: Smoking??????
« Reply #13 on: May 23, 2013 - 01:17:21 AM »
It would seem something is not right , after rebuilding , breaking in a Lot of engines you should not have that much smoke
Offline cudabob496
Re: Smoking??????
« Reply #14 on: May 23, 2013 - 01:36:41 AM »
yep, I've heard the same thing from builders. Give it another 2 to 5 thousand miles.
Kinda baloney in my opinion. A well built engine should not smoke.
What work was done on heads? New guides?
If as you say, shaved heads, then were measurements taken before assembly
to show same gap all around head/intake area.
You can measure those gaps now to a certain extent.
Also, check all plugs. If only intakes oily, then maybe intake gasket leak.
Or if only one or two plugs oily, may help locate problem.
Only so much can be shaved from heads, until intake has to be shaved.
« Last Edit: May 23, 2013 - 05:49:24 PM by cudabob496 »
2011 Kawasaki Z1000
