Author Topic: Outer Wheel House removal  (Read 662 times)
Offline Edison1970
« on: May 21, 2013 - 09:21:52 PM »
 I need some help on the next step of my repairs which is to possibly replace the outer wheel house.  I fixed most of the rusted spots on the original.  The spot that is troubling is lower leading edge that is connected to the rocker.  The steel has some pitting.  I purchased a replacement and I am on the fence to replace the whole thing.  If I do decide to replace it, how is the best way to remove it?  I see that it is sandwiched between  the inner and some bracing.  Would it be easier to drill out the spot welds with a drill bit instead of spot weld remover?
Offline steven
Re: Outer Wheel House removal
« Reply #1 on: May 21, 2013 - 09:37:27 PM »
I'm a self-taught man so take this into consideration. The "SPINE" on the wheelhouses is welded in differently than anything else on the car. I believe I read somewhere that it's called ribbon welding. I separated it on my '71 convertible Barracuda and replaced it with standard spot welds. Don't like it - at all - so on my '70 hardtop  Barracuda I left the factory original "Spine" plus the dimpled seam that is about 1" wide along the side of the "Spine".  Then I cut the "Spine" off of the new replacement  wheelhouse and fit it's Dimpled seam to the orininal one still on the car.  In other words, an over-laping seam. Appearance wise this preserved the original"SPINE" with the factory ribbon welding and I like this much better. When I'm done and apply some undercoating no one will know unless I tell them. Gool luck !!!
Offline Edison1970
« Reply #2 on: May 22, 2013 - 10:49:45 PM »
Thanks.  Tonight I decided to just cut out the leading edge a fabricate the piece.  I just couldn't see replacing the whole thing since I repaired most of it already.
