Author Topic: Proper Start to Rust Repair  (Read 639 times)
Offline anlauto
« on: May 23, 2013 - 02:33:24 PM »
Here is how major rust repair should start. The car has been stripped and primed 100% and is now welded directly to a frame table. Now you can check all the measurements against the factory specs before you start removing anything.
Kudos....to my new associates at Boothill Automotive in Erin Ontario  http://www.boothillauto.ca/   for doing it right the first time....
More pictures: http://www.alangallantautomotiverestoration.com/1971FC7383.html
Offline 73RallyeChallenger
Re: Proper Start to Rust Repair
« Reply #1 on: May 23, 2013 - 02:43:34 PM »
I don't see a lot of rust on that one...
Where is the magnifying glass smiley?
Offline anlauto
« Reply #2 on: May 23, 2013 - 03:12:19 PM »
Yea...that's one of the better ones :smilielol: Texas car originally I believe.
If you check out the link above you can see some more detailed pictures.
Basically full PS 1/4 due to accident damage. Lower DS 1/4 due to rust.
Trunk floor, two trunk extentions (rust)
Rear window filler panel (rust)
At least one inner appron, accident damage.
