Author Topic: Do you have rear disks on your car? Need help with e-brake!  (Read 3893 times)
Offline shadango
Hi folks.
I am installing a Summit rear disk brake kit on my fish.
Have a question about how the heck the e-brake cables are routed and get hooked up.
In the photo , the L shaped bracket i shown.   Supposed to mount on "the top front bolt".  Well, in that position, the bracket cant orient to allow the brake cable thru it......there are two other bolts nearby that  interfere with the bracket being mounted.......so I am confused.
This kit is a summit kit, but it seems that it is made by SSBC.  A couple other online brake places sell this same kit under their name too from what I can tell.
Hoping SOMEONE out there has the same kit and can offer some advice.
Thanks guys!
Offline rusty dodge
  • 74 challenger 440-727-3:55
Re: Do you have rear disks on your car? Need help with e-brake!
« Reply #1 on: May 26, 2013 - 09:02:01 AM »
Ive got the same kit and couldnt figure it out either. I think that you need to fab your own bracket, and get custom cables. That "L " bracket dosent fit like they show. I have an auto trans so I put it off till later.
Offline shadango
« Reply #2 on: May 26, 2013 - 09:24:17 AM »
I just tired using the other "front" bolt and it lines up and all, but the cable is 3" too short.  I dont think there is that much "slack" in e-brakes cables......right?  My picture below shows that.  Juts three inches mnore and it should line up "ok". I think I will call summit on tuesday and see what they say.   Not really crazy about how twisted the stock e brake lines get either......I wonder if they will even work that way? Picture below.
What did you do with the caliper ends of the brake hoses they provided?   They have a c-clip on the end but no where to clip it to....LOL   I was thinking I could fab something like a plate to tack to the axle housing maybe....Dont think it would be good for the hoses to just be hanging free with the steel lines on one end, would it?
In retrospect, i would have really preferred to go with a kit like Dr Diff's.   Just didnt have the extra $400  (I got my kit used for $200) and I guess this is part of retrofitting any older car anyways...LOL
« Last Edit: May 26, 2013 - 11:15:25 AM by shadango »
Offline MTS-Challenger
  • Vanishing Point - "Catch Me If You Can"
« Reply #3 on: May 26, 2013 - 10:55:53 AM »
Here is an old photo of my SSBC setup. The cable is missing but the bracket is in place.
Hope this helps
1970 Challenger R/T 440
Offline shadango
« Reply #4 on: May 26, 2013 - 11:17:54 AM »
Hope this helps
Thanks!  Looks like maybe I should flip the bracket around?  Although you dont seem to have the second bolt I have?? And I swear I tried that and it wouldnt go....maybe I have the brackets on wrong somehow?  The instructions say that the long bracket goes to the rear, the short on the front, with the ends facing in to the caliper though, and that is what I have.....
« Last Edit: May 26, 2013 - 11:25:22 AM by shadango »
Offline shadango
« Reply #5 on: May 26, 2013 - 03:01:44 PM »
Hope this helps
Is that the left side or right side?
« Reply #6 on: May 26, 2013 - 05:02:51 PM »
looks like the left side to me
Offline shadango
« Reply #7 on: May 26, 2013 - 06:27:36 PM »
Thats what I thought too, but his setup looks like it is further toward the back than mine and he used the "long" bracket on top whereas mine is on the bottom per the directions....wonder if it would work better going the same way as his?
« Reply #8 on: May 27, 2013 - 12:15:34 PM »
Driver side picture.
It's not the greatest bracket alignment but with some tweeking it will be good.
Offline shadango
« Reply #9 on: May 27, 2013 - 01:32:13 PM »
Thanks for the xtra pics!  Definately helped!  I re-oriented the e-brake l brackets like yours and now the cables reach fine.
The instructions for my kit say to have that longer black strap on the REAR whereas yours are on the front, so your calipers are oriented further toward the back than mine.....
Offline shadango
« Reply #10 on: May 30, 2013 - 08:20:46 AM »
Well, the kit is installed.  The pics here really helped!   E-brake appears to work!
Now am just waiting for the banjo/bleeder bolt that was missing from the "complete" kit I bought from a guy....had to special order thru summit.
The guy told me "Try NAPA" when I asked if he found the bolt for me.  I had to end up spending about $40 extra on this "complete" brake kit to get the parts I had to have.....
Never been dissed by a mopar guy before.
Guess there is a first for everything.
Offline shadango
« Reply #11 on: May 30, 2013 - 10:34:13 AM »
Hey mttchall --
Safe to assume this setup is still in use on your car?
I need one of the special bleeder/banjo bolts.......
I just found out that summit wont have the damn part I need for 1-2 weeks! THEN they ship it to me....so my car may be down for three weeks!!!!!!!!!!!!!!!
This sucks.
« Reply #12 on: May 30, 2013 - 04:12:39 PM »
Shadango,
Yes I'm still using SSBC at all 4 wheels.
Right now I'm upgrading the rear brakes to stainless steel flex lines and adding two adjustable SSBC proportional valves, one at the master cylinder for the front and rear brakes and the other one inline for fine tuning the rear brake (this one I can tune from inside the car just below in front of the driver seat).
Oh!, did you remember to switch out the proportional valve?
« Last Edit: June 01, 2013 - 03:25:21 PM by mttchall »
Offline shadango
« Reply #13 on: May 30, 2013 - 06:53:31 PM »
Yeah, I have an adjustable prop valve , but under the car....    :pullinghair:  LOL
So I can adjust rear bias.  I put that in when I switched to the pickup truck rear cylinders.
My car only had the distribution block (it was a drum car) but no stock prop valve.
I have Dr Diff's master cylinder.
Hoping it is a good combo!
Offline shadango
« Reply #14 on: June 04, 2013 - 07:10:26 PM »
 :ylsuper: :ylsuper: :ylsuper: :ylsuper: :bananasmi :bananasmi :bananasmi :bananasmi :bananasmi :bigsmile: :bigsmile: :bigsmile:
Brakes work!  E brake works (great!) !!   Car STOPS, no leaks!!!  Hit some potholes and the rear end is still attached!!!!!
So, looks like so far so good.   Definately an improvemnet in braking, and I havent touched the prop valve yet. Its still set for the truck rear cylinders.
I just wantt o run it a few miles as is to make sure nothing blows up, falls off, disintegrates etc.....LOL
(I guess I need to have more faith in my own work)
I really NEEDED this "win" today.....lots of disconcerting stuff happening at my workplace of 21 years and today was rough -  and to be honest I may need to be living in the fish down by the river at some point, so glad I can get it there! LOL
Not sure if I should update my other question threads or not?
Thanks to all for their advice and listening to me .  LOL
