Author Topic: 4 corner idle system  (Read 819 times)
Offline cudabob496
« on: May 27, 2013 - 01:08:19 AM »
on my 850 Holley DP, the four corner idle adjust screws seem to have backed out a turn or two on their own!
Is this common,and how do you prevent it?
Thanks
2011 Kawasaki Z1000
Re: 4 corner idle system
« Reply #1 on: May 27, 2013 - 08:10:23 AM »
over time the cork gasket around the screw will dry out & the screws can become loose , the fix is new cork gaskets
Offline cudabob496
« Reply #2 on: May 27, 2013 - 06:09:27 PM »
Thanks, ordering immediately!!
Are these them?
http://www.summitracing.com/parts/hly-26-110-10/overview/
« Last Edit: May 27, 2013 - 06:12:40 PM by cudabob496 »
2011 Kawasaki Z1000
« Reply #3 on: May 27, 2013 - 08:36:35 PM »
Yup    :2thumbs:
Offline cudabob496
« Reply #4 on: May 27, 2013 - 09:10:20 PM »
Yup    :2thumbs:
do you install dry, or put any kinda lubricant on them?
2011 Kawasaki Z1000
« Reply #5 on: May 29, 2013 - 08:14:18 AM »
I usually just push them into the metering block body dry & push/thread the screw into them , lubing them coul drecreate the problem of them moving .
Offline 73restomod
« Reply #6 on: June 03, 2013 - 10:19:10 PM »
They also have them in a rubber type.
Sent from my DROID RAZR using Tapatalk 2
