No worries
That's good info on the 904.
I believe the mounts are in front of the ears, but I know they can only go one way due to a curve in the bracket on the passenger side.
The trans mount was just what was on the 904 when I got it. Right now the trans is "bare" mount-wise and is on a jack while the cross member has the trans mount already bolted to it (1 bolt). The member has 1 bolt out of 4 in so I could swing it up and then bolt the mount the the trans, except the mounting location on the trans is too far back.
Stock V8 K member as far as I can tell.
Pics:
Left are BB brackets, I'm using the ones on the right with new rubber mounts.
Not a great pic, but you can kinda see the K frame. (Day before I bought it)
These are what I already had uploaded, I can get better pics of specific parts tonight tho if it would help.
