horn button and lock disc removal?
Author Topic: horn button and lock disc removal?  (Read 4512 times)
Offline miketyler
    • www.miketyler.net
« on: March 21, 2005 - 02:00:19 PM »
I know this is an easy one. Its got to be because I cant even find it in the manual. I need to disassemble my steering coumn so I can send it out for powder coat and cannot figure out how to remove the horn button. Push down and twist CCW right? Not mine.  :gripe:
Somone PLEASE enlighten me  :dontknow:
« Last Edit: March 21, 2005 - 07:16:16 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline inot2old
Re: horn button removal
« Reply #1 on: March 21, 2005 - 02:13:13 PM »
I just removed the one on my '73 Cuda, it just pulls off.  You may have to pry it with a screwdriver or something.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
« Reply #2 on: March 21, 2005 - 05:00:04 PM »
Yeah, just give it a yank.  :thumbs:
Offline miketyler
    • www.miketyler.net
« Reply #3 on: March 21, 2005 - 07:14:35 PM »
yeppirs, its just like you fellers said. She popped right off of there. I was gonna do that but I have broken enough stuff already  :gripe:
Ok, how about the lock disc? The book shows a crafty tool that slips around the shaft and presses a pin out. Problem is I dont see a pin anywhere. I must be missing something here  :???
72' Cuda restomod
70 Mustang Mach 1
Re: horn button and lock disc removal?
« Reply #4 on: March 21, 2005 - 07:21:30 PM »
carefully pry the steel ring up from above the lock ring &the pin is under the ring
Offline miketyler
    • www.miketyler.net
« Reply #5 on: March 21, 2005 - 08:19:58 PM »
I dont understand;I removed the lock ring already; as far as I can see the gear is swaged onto the hub. it swivels a little bit but its not moving readilly. Are you saying the gear needs to be pryed off of the hub?
72' Cuda restomod
70 Mustang Mach 1
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: March 21, 2005 - 10:20:00 PM »
Mike there is still a collar on there just like CP said.  A small screwdriver and wiggle it down from lock disk.  There is a pin under the collar.
Offline miketyler
    • www.miketyler.net
« Reply #7 on: March 22, 2005 - 06:16:14 AM »
4C - the "collar" that you are pointing at looks to be part of the gear and doesnt appear to come off. You are saying that collar should pry off of the gear and hub both?
72' Cuda restomod
70 Mustang Mach 1
Offline heminut
« Reply #8 on: March 22, 2005 - 08:11:25 AM »
If you look closely you'll see that the collar 4C has marked is a thin metal sleeve that is pressed down around the hub of the lockring.
1970 5.7 Hemi Cuda
Offline 4Cruizn
  • HEMI FISH
« Reply #9 on: March 22, 2005 - 10:47:55 AM »
Even though it looks like it is one piece . . . it is not. That sleeve does come off and the pin is under it!
Offline miketyler
    • www.miketyler.net
« Reply #10 on: March 22, 2005 - 11:02:00 AM »
Ahhh yes weedhopper  :grinyes:
Pictures tell 1000 words - thanks!!!!   :thumbs:
« Last Edit: March 22, 2005 - 11:05:10 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #11 on: March 22, 2005 - 08:30:26 PM »
ok, got er done  ;)
With a ginger tap from a chisel, the keeper collar came right off. Whodathunk it? I would have sworn it was all one pice with the lock disc. So now that she's totally disassembled I have another question. Where do you get the bearing for the cabin end of the column?
72' Cuda restomod
70 Mustang Mach 1
Offline 4Cruizn
  • HEMI FISH
« Reply #12 on: March 22, 2005 - 11:08:54 PM »
Mike I'm not sure what you're talking about. . . do you mean this??
Offline miketyler
    • www.miketyler.net
« Reply #13 on: March 23, 2005 - 07:57:05 PM »
thats the one - is that still available thru Ma Mopar?
72' Cuda restomod
70 Mustang Mach 1
« Reply #14 on: March 24, 2005 - 12:53:26 AM »
I have never tried to get one
