Author Topic: leaf springs shackle  (Read 608 times)
Offline acudadude
« on: May 31, 2013 - 12:11:28 PM »
Whats the best way to remove the leaf spring shackle or do they make a tool for the job?
Re: leaf springs shackle
« Reply #1 on: May 31, 2013 - 12:33:16 PM »
After taking the inside piece off they just pull out.  The shackle pins could be all rusted up inside the bushings though.  That would make them harder to remove.
With the back of the car on jack stands(supported at the frame) you can jack up the rear end housing to take the load off the shackle.
Offline acudadude
« Reply #2 on: June 02, 2013 - 12:55:46 PM »
THANKS burdar, Forgot to ask whats the extra bolt thats in the frame rail used for see pix
« Reply #3 on: June 02, 2013 - 01:57:29 PM »
There is a bracket that's supposed to be there.  It goes from the frame rail to the bumper guard.
Offline acudadude
« Reply #4 on: June 06, 2013 - 02:18:43 PM »
Got them off with my friendly sawzall. I got new stock ones with rubber bushings do you use any grease or lube when putting them on??? Thks
« Reply #5 on: June 06, 2013 - 03:32:10 PM »
No oil or grease.
