Author Topic: aluminum head question.  (Read 1588 times)
Offline todd383
  • I'm a llama!
« on: June 01, 2013 - 03:10:30 PM »
I want to change out the iron heads on my car and put the stealth heads on, but i have a domed piston on my 383. can the stealth heads be machined  to make it a open chamber head? I dont want to do the edelbrokes , because they dont have the factory look.
Offline ireland383
Re: aluminum head question.
« Reply #1 on: June 01, 2013 - 06:43:29 PM »
No, you can only make open to closed. I'm running domes with Stealths and have no issues. What pistons are you running? You need to check piston to valve clearance.
1971 Plymouth Barracuda
Offline 72cudamaan
« Reply #2 on: June 01, 2013 - 07:24:55 PM »
I haven't ever opened up the chambers on a stealth head, but I'm sure some material could be removed. It all
depends on how big the dome is. You might call 440 source and ask them how much material is in the chamber wall.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #3 on: June 01, 2013 - 10:28:14 PM »
Offline cudabob496
« Reply #4 on: June 02, 2013 - 12:11:47 AM »
I'm confused. Wouldn't taking metal from the aluminum head make a closed chamber an open chamber?
2011 Kawasaki Z1000
« Reply #5 on: June 02, 2013 - 07:53:43 AM »
You may want to look at an MLS gasket like Cometic , the block needs a smooth finish but it will out live any other type of gasket
Offline todd383
  • I'm a llama!
« Reply #6 on: June 02, 2013 - 07:54:08 AM »
   I have custom diamond pistons, part # is BB100DOME. and my comp. is about 9.8-1.  with the iron heads. the cam i am running is a comp extreme solid, 520-521 - 244-252 at .050 with 1.6 roller rockers. so is it possible this will work?  what pistons do u have in your car, and cam?
Offline ireland383
« Reply #7 on: June 02, 2013 - 08:04:32 AM »
Sure you could take material away to try to make them open, but could you imagine the cost involved .  I guess I should of rephrased my statement.
Offline ireland383
« Reply #8 on: June 02, 2013 - 08:09:16 AM »
I'm running KB400 pistons,  Comp 275DEH 235/482, right around 9.9 to 1 comp. As Cryco said you can adjust with head gaskets. What gasket are you running now?
Offline todd383
  • I'm a llama!
« Reply #9 on: June 02, 2013 - 08:30:23 AM »
they are felpros, these might be the #s 260-1001?
« Reply #10 on: June 02, 2013 - 08:58:15 AM »
Cometic can be ordered up to .100 thickness
