Author Topic: Hooker headers for $100.....  (Read 1075 times)
Offline GrimmyDog
« on: June 01, 2013 - 04:55:33 PM »
So, I'm still new to e bodies and was wondering if a set of unused hookers for $100 is a good price and also how is fitment?  They aren't ceramic just black paint.  Any clearance issues?  Specific model/style better than others?
It might be ugly but its a '72 barracuda with a 383/727/8.75 combination and that makes it fun.
Offline Jamiez
  • Retro
Re: Hooker headers for $100.....
« Reply #1 on: June 01, 2013 - 05:13:08 PM »
Big Block/Small Block/Hemi?  Standard Starter or Mini Starter?
Generally TTI are the best fit in headers but, others can be made to work depending on other variables
Offline GrimmyDog
« Reply #2 on: June 01, 2013 - 06:01:08 PM »
Big block headers and no idea on the starter.
Offline 72cudamaan
« Reply #3 on: June 01, 2013 - 07:26:23 PM »
Have you checked the part # to make sure they should even fit the application ?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline GrimmyDog
« Reply #4 on: June 01, 2013 - 07:43:22 PM »
He only does e bodies.  I know they are e body specific.  Bill knows my car.
« Reply #5 on: June 01, 2013 - 10:30:36 PM »
I would pass , Hooker have not fit well & may cost you more $ in the long run with installing them possibly more than once , burned plug wires , header leaks, having to add dents for clearance etc
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #6 on: June 01, 2013 - 10:58:34 PM »
Better get a hammer if you're using Hooker headers. I agree, TTI are about the best, but Doug's are a little cheaper than TTI's (they are about 2nd best for quality/fitment) and they bolt-up very well with little to no fitment problems. Why buy cheap headers if you have to beat them in and then they rust out in a year or two? True $100 bucks is a whole lot cheaper than say $800 to $1,000 for ceramic coated, but then again you get what you pay for!  :2thumbs:
        Matt B.
Matt
Offline cudabob496
« Reply #7 on: June 02, 2013 - 04:06:13 AM »
I have Hooker 2 inch Super Comps on my 496 72 Cuda.  One tube on each side is a slip fit.
Had to make 2 small dents, but having a mini starter and eliminating power steering helped.
But no leaks in 12 years. Also had them ceramic coated inside and out. Putting them in
by myself in the garage was a hassle, however.  I bought longer header bots from ARP, with
the small 3/8 drive heads, to get a better bolt "bite" into the water jackets.  Never had any burned plug wires.
I highly recommend the plumbers white sealant for pipe threads to keep the header bolts from leaking.
2011 Kawasaki Z1000
Offline GrimmyDog
« Reply #8 on: June 02, 2013 - 02:28:34 PM »
And I'm thinking I will pass.
Thanks for the honest input.
Offline rattlesnake
  • Rattlesnake
« Reply #9 on: June 02, 2013 - 08:14:07 PM »
Yea I have the same story. I bought a set of Hooker Competition headers that were advertised as fitting my exact car. Had them coated and then had to beat a couple dimples in them to clear the steering shaft and starter.  I bought a set of Dougs headers and love them. Exact fit, well made and tuck up high in the frame giving lots of road clearance and a nice look.
Ray,
keep honking I'm reloading
