Author Topic: Brad Penn Oil Zinc Level  (Read 1588 times)
Offline AMXguy
« on: June 02, 2013 - 08:50:51 PM »
I just switched to Brad Penn #1 . it says it has enough zinc and phosphate for flat tappets but I wonder if a half bottle of ZZDP on top of it would do more good than harm?  I've heard too much is as bad as not enough.
I'm not sure.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline high perf mopar
Re: Brad Penn Oil Zinc Level
« Reply #1 on: June 02, 2013 - 10:23:27 PM »
I'm not sure.
after breaking a pushrod cup due to excessive heat from not enough lubricating value due to the oil and costing 5000.00+ to fix the mess(not enough zinc in oil due to longer catalyic converter life)i like to add my own to be sure..dont trust any politiacian's,lawyers,or corporations that say they have your back.u better cover your own a$$..i would do a search on the quatity of zinc in that oil and my flat tappet requirements..i run valveoline vr-1 with an additive,,the last time i checked,been awhile that had the most zinc in it off the shelve...it could have changed by now but my additive does the rest...  to be sure..
« Last Edit: June 02, 2013 - 10:54:20 PM by high perf mopar »
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
Offline cudabob496
« Last Edit: June 03, 2013 - 12:55:27 AM by cudabob496 »
2011 Kawasaki Z1000
Offline 74 challenge
« Reply #3 on: June 03, 2013 - 07:50:18 AM »
 switched to brad Penn 1 as per the recomendations of this forum and other then some oil pressure being too high it seems to be working well.
1-8-4-3-6-5-7-2
« Reply #4 on: June 03, 2013 - 08:07:33 AM »
Currently running BP 20W-50 in my engine.  80 psi cold 40 hot
Offline aris_unlimited
  • Project in full swing
« Reply #5 on: June 05, 2013 - 03:24:10 AM »
And this is why I am putting a roller cam in my car lol.
Cuda is gone :(
74 satellite, daily driver/project now
« Reply #6 on: June 05, 2013 - 04:54:43 AM »
I hear ya, that's why I too installed a roller cam. But I used T&D roller rockers and they say to still use oil with zinc in it for their rockers so that's why I'm still using BP oil. Can't hurt I figure? I only change the oil once a year anyway with the mileage I put on so the cost is not a big issue?
Offline 73restomod
« Reply #7 on: June 05, 2013 - 07:14:57 PM »
I like BP oil, my machinist swears by it. He also gets a good deal on it, and isn't afraid to pass it on. :))
Sent from my DROID RAZR using Tapatalk 2
