Author Topic: 1970-72 E-body disk brake wheel seals  (Read 578 times)
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« on: June 04, 2013 - 09:13:52 PM »
Does anyone have a part number? I have 1970-72 disks on my car and have been stumbling through the brake components. I bought SET17 inner bearings for it as recommended and then later found out that it required SET6 Timken bearings.  :bricks1:
Anywho, I've see that there are 3 brake options listed on most parts sites yet do not know which ones to get. Any help would be greatly appreciated.
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline diyhemi.com
    • DIYHEMI.COM
Re: 1970-72 E-body disk brake wheel seals
« Reply #1 on: June 04, 2013 - 09:18:54 PM »
 :lol: Search function is your friend 5121S
However, no one carries the 5121s just the 5121. I did find a 8121s listed as a cuda option as well.
this 70-72 crap is confusing. No one has a straight answer
« Last Edit: June 04, 2013 - 09:30:49 PM by YellowFin »
Offline anlauto
« Reply #2 on: June 04, 2013 - 09:54:42 PM »
I use MOOG 6840S  :dunno: Also listed under National Oil Seal.
« Last Edit: June 04, 2013 - 09:56:44 PM by anlauto »
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #3 on: June 04, 2013 - 10:01:34 PM »
I saw that number kicked around as well. I know you know your E-bodies, so I'll give it a world. I prefer Timken or SKF quality as it is frequently used in industry as the premier lines, but Moog usually has great products too.
Anywho, thanks!
