Author Topic: Motor mounts for 440  (Read 1791 times)
Offline fcepstein
« on: June 05, 2013 - 01:00:48 AM »
Hi,
I have a base 318 model 1970 Challenger which I am re-building.  It came with a 440 RB on the side.  I am not sure what motor mounts I need.  Can I go with the stock RB mounts, or do I need a schumacher conversion kit.
Thanks, Chuck
Offline Jesus H Chrysler
Re: Motor mounts for 440
« Reply #1 on: June 05, 2013 - 08:13:42 AM »
for a v-8 to v-8 swap all you need are the stock mounts.  Schumacher mounts are repros of the stock mounts.  If you had a /6 then they have custom conversion mounts.  If you already have E body mounts you're all set.
Yes I own a 1972 Dodge Challenger Convertible T/A S/E with a 440 Six Pak. Can it get any more wrong?
{OO /===\ OO}
(OO==> <==OO)
Greg, in the middle of MA has:
1970 Dodge Coronet 440 "Zom Bee"
1972 Dodge Challenger convertible 440 5 speed.
1973 Dodge Challenger 318 "Brown Bomber"
2012 Dodge Challenger R/T Classic Blackberry Pearl.
2001 Jeep Wrangler locked, lifted and lighted.  "Jeep is a registered trademark of Chrysler Corporation"
Offline fcepstein
« Reply #2 on: June 05, 2013 - 09:40:02 AM »
Thanks.  I have the insulators and one stock mount that came with the car.
« Reply #3 on: June 05, 2013 - 10:45:52 AM »
You need the brackets for the block , the insulators could be reused but you may not want to given typical condition of them
Offline cudabob496
« Reply #4 on: June 05, 2013 - 05:13:51 PM »
ya, chuck the insulators. Too risky to use old ones.
2011 Kawasaki Z1000
Offline KingCuda440
« Reply #5 on: June 14, 2013 - 08:29:27 AM »
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: June 14, 2013 - 11:22:29 AM »
Yep! Those are it!!!
I have some spare rubber mounts if you want to buy some as I went with the steel core ones.
