Author Topic: Removed my cluster - Cluster - Done.... I hope!  (Read 12037 times)
Offline BIGSHCLUNK
« on: June 06, 2013 - 09:24:33 PM »
Ok, I started a thread in the electrical section. You ever notice how one thing leads to another??? The burnt terminal blocks on the fire wall was my next discovery. My amp meter has been a bit erratic for awhile.  First off if your going to due this tape the entire top of the colum, I got lazy and ksksksksksk  put a nice scratch in the paint.  :banghead:  When I got the cluster out there was some discoloration on the back of the cluster case. But when I pulled out the amp meter it looked good (to me anyway). I thought I'd see something burnt looking??  :dunno: Opinions........... ??
« Last Edit: July 19, 2013 - 11:26:00 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: Removed my cluster -
« Reply #1 on: June 06, 2013 - 09:31:50 PM »
1.  I would've dropped the steering column and if necessary pull the steering wheel to get it even lower.
2.   I would enter your fingers in the ugly finger contest.    :biggrin:
Don't take it personally.
If you saw mine, I would be a close competitor.
Offline anlauto
« Reply #2 on: June 06, 2013 - 09:35:30 PM »
Gauge "looks" okay... :dunno:
Offline JayBee
« Reply #3 on: June 06, 2013 - 09:42:34 PM »
My opinion - The nuts on the ammeter studs make a far better, more solid, connection than the spade connectors in the bulkhead. That's why it's burned where it is.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline BIGSHCLUNK
« Reply #4 on: June 06, 2013 - 09:51:43 PM »
No offense taken TC I'm just glad they still work, fugly as they may be!!  :grinyes: My hands have really taken a beating over the years. have had surg on both  :blah: wrenching is getting progressively harder as time goes.  :crying:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
« Reply #5 on: June 06, 2013 - 09:53:16 PM »
Thats what I thought??
John (jaybee) dont you think there would at the least have some discoloration??
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline BIGSHCLUNK
Re: Removed my cluster - what do think of my amp meter?
« Reply #6 on: June 06, 2013 - 09:58:38 PM »
BTW the insulators on the meter were good on both sides of the cluster case............
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #7 on: June 06, 2013 - 10:01:00 PM »
The aluminum housing looks discolored though?  :dunno:
« Reply #8 on: June 06, 2013 - 10:04:31 PM »
Regardless of how it 'looks', it is a poorly designed electrical system. IMO, since 100% originality is not important to you (i think?), bypass it and use a voltmeter to monitor your charging system. Sending full alternator output through the bulkhead connector and the amp gauge is just asking for problems. And the older it gets, the more likely a problem will occur.  :2cents:
Offline BIGSHCLUNK
« Reply #9 on: June 06, 2013 - 10:11:53 PM »
Scott, you are correct on both points.  :grinyes:  It just seems odd to say the least that the firewall blocks show damage (both alt & batt) and this piece looks fine.  :screwy:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #10 on: June 06, 2013 - 10:12:38 PM »
 :iagree:  If you are staying completely stock and aren't adding any extra electrical loads it's OK.  As soon as you start adding anything extra, you're asking for trouble.  It's simple to change.
« Reply #11 on: June 06, 2013 - 10:14:58 PM »
I still have my amp gauge hooked up and so far so good but I ran a heavy gauge wire from the alternator to the battery in an attempt to sort of bypass it somewhat?
Offline RCCDrew
« Reply #12 on: June 06, 2013 - 10:22:31 PM »
Hijack! How do you bypass the ammeter? I need to do this.
« Reply #13 on: June 06, 2013 - 10:38:36 PM »
Well, heat builds up (regarding electrical current flow) wherever the resistance is not zero. Wires in good condition can be considered zero ohms. Connectors in good clean condition are close to zero ohms, but not as good as a solid piece of wire. The problem with connectors carrying full system current flow is they have some resistance. And a small resistance with a lot of current translates into some heat being created. When heat is created, the metal connectors expand. When you shut the car off, the metal contracts. After years of expanding and contracting, the connectors are not as 'tight' fitting, creating higher resistance. Which then creates more heat, eventually melting or burning the connector. As Jaybee mentioned, the ammeter has better, more solid connections than the bulkhead connector, so your first indication of an electrical system issue was at the bulkhead connector. If one of the nuts on your ammeter had loosened a bit over the years, your ammeter gauge would have started to melt instead. (Glad it didn't)
