Author Topic: Where can I get 2 of these?  (Read 1458 times)
Re: Where can I get 2 of these?
« Reply #15 on: June 09, 2013 - 02:54:38 PM »
Brad,
I know this topic was started by BIGSHCLUNK, but would you happen to have a couple more spares?  Mine are in the same condition as his.  I just had my cluster done by Redline, but I don't know that they have these to replace when they're damaged.  Thanks.
Sorry I just had the one extra scrap speedo. (scrap because I tried to take it appart!  :icon16:)
Bigs they are on there way, just got back from the post offfice.  :wave: 2 weeks?  :dunno:
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #16 on: June 09, 2013 - 02:55:46 PM »
This is likely a common issue.  These are mine.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline filmsurgeon
« Reply #17 on: June 09, 2013 - 02:58:31 PM »
Thanks.  I'll check with Redline tomorrow to see if they have any, and if not, what they do as an alternative.
Offline BIGSHCLUNK
« Reply #18 on: June 09, 2013 - 07:06:59 PM »
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline 73EStroker
« Reply #19 on: June 12, 2013 - 07:55:15 AM »
OK here goes. Looks like the steel insert sets the depth of the screw so that it can be tight without squashing the rubber. So find small rubber grommets the same size then hit a model railway hobby shop and buy about 2" of brass tubing to fit the screw shank, cut it to length and insert into grommet and voila. The brass tubing has a thin wall and will work.
Barry (Salmon Arm)
Offline filmsurgeon
Speedo Mounting Screws (Rubber Isolators/Washers/Bushings)
« Reply #20 on: June 20, 2013 - 02:29:54 AM »
If anyone needs to replace theirs, here's how you can do it:
Buy these rubber grommets from Lowe's (see 1st photo), or use similar.  Then, trim off one of the rings with small sharp scissors, or nail clippers (don't "slice" it off with a knife as this will cause too short of a "bushing").  If you have the steel cup-shaped inserts (see 2nd photo), push them into the center holes, then place into the back of the cluster housing, insert screw and tighten.  Worked perfectly for me (see last two photos), and was a cheap and effective repair.  Hopes this helps.
Offline JayBee
« Reply #21 on: June 20, 2013 - 07:23:29 AM »
Thanks for the tip. Looks like a great solution.   :thumbsup:
John
1970 Barracuda convertible
2014 Toyota Avalon
