Author Topic: Exhaust bung  (Read 1999 times)
Exhaust bung
« on: June 08, 2013 - 10:08:16 AM »
I am about to weld in a bung for an A/F meter. Are you supposed to drill the hole a little smaller than the OD of the bung and weld it on or are you supposed to make the hole the same as the OD of the bung and have the bung flush with the inside surface of the exhaust pipe? Or... it doesn't matter? Do it either way?
Re: Exhaust bung
« Reply #1 on: June 08, 2013 - 10:10:50 AM »
I just made the hole a little larger than the O2 sensor and welded on the bung.
Re: Exhaust bung
« Reply #2 on: June 08, 2013 - 11:32:56 AM »
 :iagree: I would not weld the bung into the pipe just on the outside so the sensor will fit into the pipe
Offline Katfish
  • 70 Challenger
Re: Exhaust bung
« Reply #3 on: June 08, 2013 - 12:33:50 PM »
 :popcorn:
Take some pics and post a parts list if you can, please.
Interested in this too
Thx
Re: Exhaust bung
« Reply #4 on: June 08, 2013 - 12:48:50 PM »
Thanks Brad, CP.
Will do Rod.
Offline cwestra
Re: Exhaust bung
« Reply #5 on: June 08, 2013 - 01:43:08 PM »
I just finished installing bungs on my pipes for my AFR.  I drilled a 7/16" hole and centered the bung over it prior to welding.
Corey - in Northern Indiana
Re: Exhaust bung
« Reply #6 on: June 08, 2013 - 02:07:46 PM »
Also.... in my destructions....errr INstructions  :icon16:  it said to mount it on top of the pipe so any condensation would drip off it and that would make the O2 sensor last longer. :2cents:
Offline footin70rt
Re: Exhaust bung
« Reply #7 on: June 08, 2013 - 03:20:29 PM »
I had gotten a bung a few years ago that had a small step on it that fit into the pipe to help center it. Sorry can't think of the manufacturers name, but they are out there and was the same price as a regular bung. Summit has one.
 http://www.summitracing.com/parts/sum-g2990/overview/
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline shadango
Re: Exhaust bung
« Reply #8 on: June 29, 2013 - 11:20:51 PM »
(insert beavis and Butthead laugh here)...he said   BUNG.
I am the great Cornholio! I need TP for my bunghole!      :bigsmile:
Sorry guys.
I saw this threada few time and finally couldnt resist!
I was actually considering doing this - but am too afraid of ruining my pipes!  I have never welded exhaust pipe before...guess its time to practice!
Re: Exhaust bung
« Reply #9 on: July 03, 2013 - 11:50:30 AM »
I got mine mounted at the 2 o'clock position,  did you get yours mounted vertical? Floor was too close to get it any higher.
Re: Exhaust bung
« Reply #10 on: July 07, 2013 - 12:31:47 AM »
Yep, on mine it is mounted at 12 o'clock on the collector
Re: Exhaust bung
« Reply #11 on: July 07, 2013 - 01:01:06 AM »
Interesting. Mine's on the collector as well. And we have the same headers. Hedman ceramic elite -038's  :clueless:
Offline mr_340
Re: Exhaust bung
« Reply #12 on: July 07, 2013 - 10:21:15 AM »
I have mine at about 2 o'clock but after the collectors, hooker supercomps herte. ( tried to load a pic but file too large :nono:)
