Author Topic: Holley Carb Questions  (Read 1373 times)
Offline cwestra
« on: June 08, 2013 - 03:49:06 PM »
While taking apart the front carburetor on my AAR I noticed several imbedded particles on the top side of my throttle plates.  I've had these carbs apart several times before but never noticed this so I think it is recent.  I've run the car with the air cleaner on.  Any idea what could have caused this?  Is this common?
Also, I've attached a picture of the inside of the main section where the float attaches.  There seems to be delamination taking place inside.  Has anyone else experienced this on Holley carbs (these are original carbs)?
Thanks.
Corey - in Northern Indiana
Re: Holley Carb Questions
« Reply #1 on: June 09, 2013 - 09:46:27 AM »
Alcohol is very corrosive , my guess ........
 ethanol fuels
Offline cudabob496
« Reply #2 on: June 10, 2013 - 07:08:08 PM »
water in gasoline, or fuel tank?
flush out fuel system maybe?
fuel filter a bad one? Not filtering or breaking down?
Air filter bad?
Did you change your fuel source recently?
Maybe the gasket shown is cheap and breaking down?
Not sure that is de-lamination. More likely a casting flaw? Cheap metering block material?
That part of carb is in vacuum. Maybe carb not sealed correctly, and needs new gaskets, as vacuum is
drawing in debris? Or air filter not sealed against carb top?
maybe use the new blue reusable gaskets?
« Last Edit: June 10, 2013 - 07:32:33 PM by cudabob496 »
2011 Kawasaki Z1000
Offline cwestra
« Reply #3 on: June 10, 2013 - 07:32:38 PM »
  The particles seem too large to be coming from the fuel.  Can particles that size actually make it through the jets and passages?
Offline cudabob496
« Reply #4 on: June 10, 2013 - 08:10:46 PM »
jets can be a pretty big hole, but not likely.
2011 Kawasaki Z1000
Offline jimynick
« Reply #5 on: June 10, 2013 - 11:11:51 PM »
With the size and shape of those marks, it seems like they're high velocity impacts and I don't think any intake flow would carry them that fast; however, I do think that a backfire would generate the speed necessary to drive them into the throttle plates and I wonder if the old gal ever coughs when you whack it wide open? Pull one of the butterflies and stick it under the kids microscope and see what's there. If there's chunks imbedded you'll be on the path to figuring out where they came from. Just my  :2cents:
Offline cudabob496
« Reply #6 on: June 11, 2013 - 02:22:38 AM »
Good point! A backfire could puke up all kinds of carbon/oil residue mixture.
2011 Kawasaki Z1000
Offline cwestra
« Reply #7 on: June 11, 2013 - 05:57:42 AM »
Thanks, guys.  Although it seldom backfires, it has done it once or twice, and that amount of abrupt force certainly could explain it.  It's odd that it's only on the front carb though.  Just curious.
Offline 72cudamaan
« Reply #8 on: June 11, 2013 - 08:39:44 AM »
The engine would only backfire where there is fuel.
If I cant fix it, it's broke
Andy  (phukker whither)
